Sponsored by: Innova
L.E.D. Resistance Value
Old Aug 4, 2006 | 12:48 PM
wiz1500's Avatar
wiz1500
Default L.E.D. Resistance Value
I have a high intensity L.e.d. that require a 470 ohm resistor to run on 12 volts D.C.. If I start running more than one l.e.d. with one resistor I lose intensity.I tried to reduce the resistance and this resulted in the LED's dimming and not getting brighter......
I think I have my train of thought back words do I have to increase my value?????
I am trying to run 18 LED's off of one resistor.....I no ohm's law comes into play but electronics class was a long time ago.
Can someone help me with the formula that would apply....
And do it for me...
Thanks in advance...
Old Aug 4, 2006 | 12:51 PM
pk1's Avatar
pk1
http://metku.net/index.html?sect=vie...calc/index_eng
Old Aug 4, 2006 | 12:54 PM
wiz1500's Avatar
wiz1500
Where is the do it for me part?????
That is exactly what I was looking for....
I thank you very much.......
You have a beer coming on WIZ....
Old Aug 4, 2006 | 02:21 PM
MAGRED2001VETTE's Avatar
MAGRED2001VETTE
be careful, when you over power they start to dim and never go back to being bright again
Old Aug 4, 2006 | 02:24 PM
MAGRED2001VETTE
12.0 volts-2.0 volts=10volts
10volts/.02amps=500ohm resistor~or what you said 470
you want 2 LED's:
12.0-4.0=8
8/.04=200ohm resistor for 2 LED's
Old Aug 4, 2006 | 09:01 PM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
I typically just solder in one resistor per LED as they are cheap to buy, and when soldering them in line an heat shrinked, they are still very inobtrusive...
Old Aug 5, 2006 | 12:14 AM
wiz1500's Avatar
wiz1500
Thank you all for your input. I used a res. for each led. To run 18 I would need a 5 watt res and there could be a heat problem.
Old Aug 5, 2006 | 12:36 AM
jfb's Avatar
jfb
Way cool, careful you don't get sunburned there!
To L.E.D. Resistance Value
