Sponsored by: Innova
Need C4 Audio Help PLZ!!
Old Aug 9, 2006 | 11:28 AM
bangand0lufsen's Avatar
bangand0lufsen
Default Need C4 Audio Help PLZ!!
Does anyone know how to take the front bose speakers out. Its a 93 40th with bose gold series.. I took out the 2 screw on the outside after you open the door but its still very stuck any ideas or help would be great thanks.
Old Aug 9, 2006 | 01:06 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
There should be more than two screws-look along the outside of the sill cover, and you may want to remove the piece that covers the inside edge were the rug meets the door sill. the speaker cover is attached by velcro to the speaker enclosure, and is very hard to remove; make sure the sill cover is loose before trying to remove the speaker cover.
Hope this helps. If you are going to work on your car, you should get a helms manual; they are worth there weight in gold.
Randy
Old Aug 9, 2006 | 01:48 PM
bangand0lufsen
yes that did help allot i got everything lose just cant seem to get it out does it just need some more tugging because of the velcro
Old Aug 9, 2006 | 02:17 PM
bogus's Avatar
bogus
the velcro can be a bitch.
Old Aug 9, 2006 | 11:30 PM
RandyJ75's Avatar
RandyJ75
I almost broke my f*****g hand pulling it off..
Good luck
To Need C4 Audio Help PLZ!!
