CarPC Guys Come on in.
components that are needed. best thing to do is copy someone that has already done it. if you check out the link in my sig i have a list of everything that i used. pretty much you need:
motherboard (via epia mini itx are the best imhho)
ram
psu and shut down controller (m2-atx)
screen
soundcard (the onboard sound isn't all that good. For most applications i'd probably recommend an active x-over and a usb dac for great sound. but you can get away with traditional soundcards too)
gps reciever/mouse thingy
hardrive (some say you need a 2.5" laptop drive..this is b.s. i've used a 3.5" for a year w no problems)
case
amp
speakers
i thnk that is about it (off the top of my head) but i could be leaving something out
In the link in my sig i have a complete breakdown on page 5 i think. check it out.
Motherboard--EPIA SP13000
Memory-------1 GB DDR PC3200 DIMM
Power Supply--M2-ATX 160W DC-DC
OS------------Windows XP Home
Monitor-------Lilliput 7" VGA Touchscreen 619GL
CD/DVD Drive--Panasonic Slot Load DVD-ROM/CD-RW
Sound---------Soundblaster Audigy2
Keyboard-----MINI PS2 USB Keyboard
Do I need Wifi adapters and bluetooth?
i've added notes on your setup:
Motherboard--EPIA SP13000 -- good board -- i have the m10000 and it does a great job. the 13000 is a better board.
Memory-------1 GB DDR PC3200 DIMM --- go with 512. 1 gb will slow boot times and not net you that much of an improvement for what we use these computers for
Sound---------Soundblaster Audigy2-- this is a popular route but not my cup of tea. if you get amps with internal x-overs i'd opt for the usb dac or an m-audio audiophile soundcard. the audigy's don't have that high of an output voltage (i think they are about .2volts) where as the dac and m-audio (also the echo gina 3g card which i have) alll have higher outputs. check out this thread: http://www.mp3car.com/vbulletin/show...hlight=usb+dac
i've talked with this guy during the developmental stages of this project and if i didn't have a unique situation i would definately go this route.
Do I need Wifi adapters and bluetooth? -- nope, you can add those at anytime if you feel like it.
What do you think?
Jay
The nice thing about the dac is that it bypasses windows k-mixer and it's the prefered method of getting music off of a computer for almost every audiophile out there that is integrating a computer into there setup. If you combine that with an active x-over and eq; from audio control for instance. you will have a very solid system right there.
if you are going the pxa-h701 route and you would like a bezel that was made for that and a 7" xenarc, hit me up because i have one sitting in my closet that i plan on refinishing and selling when i send my new piece out to be refinished.
Jay
the x-over i'm using is a zapco unit...err..i forgot the model # so i'll have to check that out tonight. I probably wouldn't recommend the zapco products for you case since they require a special power supply if you dont hook them up to a zapco amp. and then they also require a converter to change the balanced signal to an unbalanced signal (rca) and vise versa.
This is about the best looking console I have found yet:
http://www.mp3car.com/vbulletin/showthread.php?t=59492
heh...err that is a photochopped image
how fast do you need your pc to be? i am running 1 ghz proc and 512 mb of ram and have never had any problems with it being too slow. unreliable? many of us have had pc's in our cars for years and haven't had any glitches what so ever. I've read of a few people that have totalled their cars and the pc was fine after the crash. Please state some facts and personal experiences to support your statement
how fast do you need your pc to be? i am running 1 ghz proc and 512 mb of ram and have never had any problems with it being too slow. unreliable? many of us have had pc's in our cars for years and haven't had any glitches what so ever. I've read of a few people that have totalled their cars and the pc was fine after the crash. Please state some facts and personal experiences to support your statement OOOOOO FIGHT!!!!!
