Sponsored by: Innova
Help w/ amp's and speakers!!!
Old Aug 28, 2006 | 11:17 PM
SpiralCoupe's Avatar
SpiralCoupe
Default Help w/ amp's and speakers!!!
I'm getting some sort of interference from the rears. Installed Polk DB6500 components in the front, DB525's in the back, and a JL stealthbox for a sub. Speakers powered by a kicker 350/4 and sub by a 250. Also used a PAC oem24 module. Now, only the rears make noise when the volume is turned down. We tried different speakers, amps, cabling, but nothing would get rid of the noise. Any ideas???
Old Aug 28, 2006 | 11:27 PM
DPG's Avatar
DPG
St. Jude Donor '06
bad ground? or is there something with the adapter?
Old Aug 28, 2006 | 11:34 PM
SpiralCoupe
We moved the ground, no luck. I am leaning toward the adapter myself. But, I'm all ears if anyone has a suggestion.
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
I used the Peripheral piece called the GMCO in CF member Gabel1's 2006 C6, and it seems to work fine.
You may have a bad PAC piece.... I have seen it happen...
Old Aug 28, 2006 | 11:54 PM
SpiralCoupe
Old Aug 29, 2006 | 01:22 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
try swapping where the rcas go into the amp flip the fronts and rears, and see if the noise moves to the front of not.
Old Aug 29, 2006 | 01:33 PM
SpiralCoupe
Will do.
Old Aug 29, 2006 | 07:09 PM
Steve Germany's Avatar
Steve Germany
Just cut the line level adaptor off of the GM-24 and solder in RCA jacks. A little work but it will save you hundreds of dollars over installing a JL cleansweep,
To Help w/ amp's and speakers!!!
