Sponsored by: Innova
C4 BOSE CD Player Problem
Old Sep 10, 2001 | 11:37 PM
out2run's Avatar
out2run
Default C4 BOSE CD Player Problem
Any suggestions on repairing this problem?
The inserted CD (only auto loads when cd is inserted and BOSE is then turned on) makes a static/popping noise while playing. To eject the cd, you have to depress and hold the eject button. Every thing else works with the system.
:confused:
Old Sep 11, 2001 | 01:19 PM
R23HTC's Avatar
R23HTC
Default Re: C4 BOSE CD Player Problem (out2run)
Unforunately this is a common problem with the stock unit. It will only get worse.
Options:
1. Buy a new stock unit.
2. Send the old one off to be repaired.
3. Buy new equipment and hopefully not every have that problem again.
I went with #3. Why spend good money on outdated equipment. I'd rather have modern technoligy than new old!
Old Sep 12, 2001 | 12:11 AM
out2run's Avatar
out2run
Default Re: C4 BOSE CD Player Problem (R94 LT 1)
Thanks for the suggestions.
I have found a place "MK Enterprises" in Longwood, FL that will repair the unit for a flat fee. I may just pull the unit and send it to them.
Next question...... Where can I get info on removing the unit?
Old Sep 13, 2001 | 10:29 AM
Reverend Nasty's Avatar
Reverend Nasty
This link may get the job done. It helped me remove mine.
http://www.carstereohelp.com/strcorvette.htm
Any questions you have just reply to my post and I'll answer them as best as I can. I ripped mine out completely a month ago and installed an after-market setup. Good luck!
Old Sep 13, 2001 | 11:19 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: C4 BOSE CD Player Problem (Reverend Nasty)
Removal is fairly straight forward. You need a Philips head and a 7MM driver.
1: Open up the center console. Lift up the carpet on the front corners inside the console just enough to expose the two 7MM screws underneath. Remove these screws.
2: Remove the ashtrays/cupholders. Underneath you will see a 3rd 7MM screw. Remove this as well. The panel will now slide to the rear and expose the lower portion of the panel covering the radio.
3: Remove the vent above the radio. It has two philips head screws and will pull out after these are removed.
4; remove the 7MM screws on the panel surrounding the Deck. There will be some on the bottom and top. I think its 3. After all these are removed you will feel the panel is held still. These are clips behind the panel. carefully pull the panel so that the clips let go.
5: The screws securing the deck should now be visible. Remove these and the deck will be loose. Carefully remove the deck and unhook the wire harnesses and antenna wire behind it. I like to put black tape on the end of the harnesses after removal.
Reverse the procedure to put the dash back together.
This is the procedure for the 6speed trans. If you have an auto, there may be more screws so be careful. I like to keep the screws in a cup so they don't get lost. Also make a note of which screw goes where as they are of different lengths.
Good luck
92TripleBlack
:cheers:
Old Sep 14, 2001 | 07:05 PM
out2run's Avatar
out2run
Default Re: C4 BOSE CD Player Problem (92TripleBlack)
Thanks for the unit removal information.
To C4 BOSE CD Player Problem
