I'm in the process of installing the new stereo and all of the sudden last night the nav system won't power on. It happened once while I was in vegas a few weeks ago but when I went out later to the car it turned on fine. Haven't had the problem since then. Does anyone have any ideas whats going on?
yup somethin is semi loose, sometimes u get a connection, othertimes not so much
As I recall you still have the stock head unit? Unusual that a wire or harness would come loose, but certainly not unheard of. Have you put anything inline or tapped for line level output?
You're right, I still have the stock HU. I haven't put anything in or take anything out since I took out my neucleus 2 weeks ago.
Sounds like a loose harness or loose wire in the harness then. Which head do you have again? Probably the same harness regardless, but I'll check my service manual and see if I can identify which wire you need to look at for HU power.
