Sponsored by: Innova
Remote Start Problems Viper 560
Old Oct 13, 2006 | 10:08 PM
minytrker's Avatar
minytrker
Default Remote Start Problems Viper 560
I had my friends shop install a viper 560 remote start in my Z06. The problem is the car wont crank at all with the remote. If its running you can remote start it and take out the key. They know there is a wire wrong but dont which one, its hooked up the way DEI said to do it. They couldnt get ahold of the tech rep who was familar with vettes. The installer who has done a bunch of these no longer works there, he just did the start part. The alarm is installed really clean and everything else works, remote trunk, remote gas door and so on. Any idea's?
Old Oct 14, 2006 | 09:57 PM
scott_fx's Avatar
scott_fx
sorry, can't help you, but ttt for you
Old Oct 14, 2006 | 10:49 PM
Mtrhd329's Avatar
Mtrhd329
Assuming that your car is a newer model.....i put in 2004 here is the wiring direct from DEI who makes Viper. I work at a stereo shop and this is what we use to install alarms. If your car is a stick then you will have to have the vehicle in Neutral for it to start. When you engage the remote start from the keypad does the fuel pump prime?
12volts
red (60A), red (60A)
ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green/black - ign harn or BCM, pnk 32P plg,pin C14
Power Lock red/black - driver door module in door
Power Unlock orange/black - driver door module in door
Lock Motor gray 5wi driver door module in door
Unlock Motor tan 5wi driver door module in door
Parking Lights+ brown + headlight switch
Parking Lights- yellow/black - BCM, green plug, pin A5
Hazards same as turn signal wires
Turn Signal(L) lt. blue (F), yellow (R) + steering column
Turn Signal(R) dk. blue (F), dk. green (R) + steering column
Reverse Light dk. blue - BCM, pink 32 pin plug, pin C1
Door Trigger gray/blk (L), black/wht (R) - BCM, pink 32 pin plug, pins C2, D1
Dome Supervision gray/black - BCM, green plug, pin A3
Trunk/Hatch Pin red/black - BCM, pink 32 pin plug, pin C12
Hood Pin pink/black (export model only) - BCM, pink 32 pin plug pin C9
Trunk/Hatch Release lt. blue - BCM, pink 24 pin plug, pin B9
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green - driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white ac cluster or PCM, red plug, pin 10
Wait to start N/A
Brake Wire white or lt. blue + brake pedal switch
Parking Brake tan/white - parking brake switch
Horn Trigger black - column or BCM, pnk 24P plug, pin B10
Memory Seat 1 white - driver door module in door
Memory Seat 2 purple - driver door module in door
Memory Seat 3 N/A -
Old Oct 15, 2006 | 05:32 PM
minytrker's Avatar
minytrker
I think we found it, gonna mess with it next week. Its something with vats, because whenyou rmoete start it with the key in it runs till you pull the key out.
Yes I park in N usually but I have several differnt safty's built into where it only starts when the car is in N. The car will not start in any gear.
Old Oct 15, 2006 | 08:21 PM
Mtrhd329's Avatar
Mtrhd329
with your car there is a module that the shop that put in your alarm should have wired in tadem with the remote start relay module. This module houses an extra key and that key is used to bypass the vats so that the car sees the vats at all times and will start right up. Take it back to your shop. if they are reputable they should warranty their work. Or at least tell you how to get it to start
Old Oct 16, 2006 | 04:58 AM
minytrker's Avatar
minytrker
I have that already. I think the box I have uses a resistor in place of a key. They just have a wire hooked up wrong on the box. I had to install that box on my civic with the extra civic.
Its my friends shop so i know it will get fixed, I was just trying to help him out.
To Remote Start Problems Viper 560
