Sponsored by: Innova
boost gauge install
Old Oct 25, 2006 | 09:07 AM
DEVETTE's Avatar
DEVETTE
Default boost gauge install
Hey there guys,
I am installing an APC boost gauge in a 2000 C5. This is a gauge that is backlit bright during the day and dimmer at night so it needs a constant 12v even when the ligths are not turned on. So the gauge has an orange labeled for 12v lighting and red for 12v ignition. I've used several sources, ie: fuse #22, even running a direct wire from the guage to the battery to get a constant voltage, but every time, the gauge doesn't illuminate. It will only illuminate when I turn the lights on. Is there another source I should be tapping into? Thanks for the help.
Daniel E
Old Oct 25, 2006 | 09:41 AM
DPG's Avatar
DPG
St. Jude Donor '06
try using the HVAC dimmer. its the tan wire on the HVAC harness. I think its in the C5 FAQ. If im wrong some one else please chime in. hope this helps
Old Oct 25, 2006 | 09:44 AM
DEVETTE's Avatar
DEVETTE
what about the radio light wire that shows the clock? Thats on all the time.
Old Oct 25, 2006 | 09:50 AM
DPG's Avatar
DPG
St. Jude Donor '06
I think that might be the case with the HVAC dimmer wire. penta might have a better idea though.
To boost gauge install
