Sponsored by: Innova
remote volume control
Old Oct 26, 2006 | 09:17 PM
scott_fx's Avatar
scott_fx
Default remote volume control
Hey guys, quick question. does anyone know of a volume control that i can put inline after my dac? i have the opp. to get a crystal dac 192/24bit, burr-brown all that good jive. but i need to figure out a way to control the volume. any ideas?
Old Oct 26, 2006 | 09:27 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Scott, I just have to throw this out there... you're
Old Oct 26, 2006 | 09:32 PM
scott_fx's Avatar
scott_fx
haha...KEEP IT ON TOPIC...JEEZ I hate when people go off topic
Old Oct 26, 2006 | 09:51 PM
scott_fx's Avatar
scott_fx
i found this...but i'm not sure i'm up for any suface mount soldering.
http://www.twistedpearaudio.com/joshuatree%5Cjt.aspx
Old Oct 26, 2006 | 09:55 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
What's your component layout? Your DAC should feed an input on your head, and that's where you'd get gain control, no?
Old Oct 26, 2006 | 09:58 PM
-=Jeff=-'s Avatar
-=Jeff=-
Those pictures are not surface mount? that is thru-hole soldering..
Send it to me, I will put it together for you.. (14 years of Surface mount soldering)
Old Oct 26, 2006 | 09:59 PM
VinceC5's Avatar
VinceC5
send it to me, I'll do it for you.
Old Oct 26, 2006 | 10:56 PM
scott_fx's Avatar
scott_fx
oh i thought the things on the back (relay looking things) were surface mount. i'll send it to you if you really want to do it, that would help me out a lot! I'm not all that confident on my thru-hole either. i've done it but i'm worried that my novice soldering may affect sound quality.
i'll send you a pm
I'm waiting for a feedback from them to tell me what kit i need exactly... i think it is the most expensive one...lol
my component layout is:
car pc > crystal dac > ldx-23 tube active x-over > amps (3)
the guy that is selling me this dac says that i need a preamp stage to control volume after the dac. makes sense to me. the zapco unit and the alpine pxa-h701 both use this same technique. do you have another idea? i'm open to all possibilities
thanks.... all you guys rock! i dont care what anyone says! this forum isn't useless...
Old Oct 27, 2006 | 08:37 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I was thinking in home theater terms. Normally an outboard DAC will feed back into a pre-amp, which obviously ain't how you're doing things. My bad.
Old Oct 29, 2006 | 10:40 PM
scott_fx's Avatar
scott_fx
wow... the owner (i assume) just offered to build it for me free of charge! this guy has been really helpful too. i recommend going with this guy if any of you are insane like me and go with a dac
Old Oct 30, 2006 | 08:37 AM
-=Jeff=-'s Avatar
-=Jeff=-
Very Cool Scott..
Let me know if you need soldering skillz..
To remote volume control
