Sponsored by: Innova
Sirius install location?
Old Oct 27, 2006 | 11:42 PM
spiral04's Avatar
spiral04
Default Sirius install location?
In the c5 audio section, it says you can install it under the rear bumper skin. My installer says that the metallic paint I have wil disrupt the signal. He suggest that I install it on the very front of the dash nearest the windshield. Anyone heard of the paint thing? What have you guys done? I'd like to keep it as stock looking as possible. Thanks for the help!!!
Old Oct 28, 2006 | 12:06 AM
Bret01Z06's Avatar
Bret01Z06
If I have mine my rear bumper sitting on the frame rail. I was thinking about mounting it on the metal under the dash.
Old Oct 28, 2006 | 12:23 AM
EatRice's Avatar
EatRice
Install everything but the antenna. Then pull a tail light and stick the antenna under the bumper. If it works you are good to go. If not you will need another location. I think it will work fine there. They work best if you put it on top of metal....like the rear bumber under the bumper cover.
Old Oct 28, 2006 | 12:06 PM
spiral04's Avatar
spiral04
Old Oct 28, 2006 | 09:52 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Where did you mount your reciever?
Old Oct 29, 2006 | 07:56 AM
finnor's Avatar
finnor
He is smoking some serious ^%!^&#$. I had mine installed in the rear bumper on my c5 and put the unit in the ashtray. Occasional drops, but you will get those no matter where you put the antenna.
--Tor
To Sirius install location?
