Sponsored by: Innova
C5 Navagation System
Old Nov 5, 2006 | 03:59 PM
jaybird81's Avatar
jaybird81
Default C5 Navagation System
My dad has a 2003 coupe with the six speed. He is looking to get an after market Navagation system. He was looking at an Avic-N3 but is not sure if he will have enough room when the screen is out with the shifter. Does anyone have that model or another model or any other advice you can give about a navagation system in a C5. Would the C6 navagation system fit in a C5?
Old Nov 5, 2006 | 06:45 PM
IDM's Avatar
IDM
Yes, I have the same question too. What is the best nav system to get for the C5. I want to purchase one soon.
Old Nov 5, 2006 | 08:11 PM
dmoran1845's Avatar
dmoran1845
I just put a Pioneer AVIC Z1 in my 98 Nass Blue Coupe. I had an installer make the electrical connections and I had to cut and grind the rest. It will fit but does require some modifications.
The AVIC Z1 has some great features to it.
Old Nov 5, 2006 | 09:30 PM
DeeGee's Avatar
DeeGee
I have an AVIC X1R (same unit as the N3). The fit is reasonably complex for DIY but no problems with fouling the shifter if you use the stock position. If you reverse the HVAC its a lot tighter. The problem is that the screen covers the AC vents
Old Nov 6, 2006 | 08:49 AM
IDM's Avatar
IDM
That's nice!!
I'm looking for a double din unit that is flush all the time like a little tv screen
Old Nov 6, 2006 | 10:01 AM
mud flap's Avatar
mud flap
Any Picts?
Tug
Old Nov 6, 2006 | 06:00 PM
dmoran1845's Avatar
dmoran1845
As soon as I can clean up the plastic molding, I will get some out. There are 1/4-1/2 inch gaps on either side right now. I am trying to get that to look better. The screen is flush with the dash now. I will try to get some pictures of its current state.
Old Nov 9, 2006 | 12:52 AM
spiral04's Avatar
spiral04
Originally Posted by IDM
That's nice!!
You might try the Eclipse AVN units.
Old Nov 9, 2006 | 07:35 PM
spiral04's Avatar
spiral04
On a thread right around yours there was a link to the national corvette registry parts section where they would customize the bezel for you.
To C5 Navagation System
