Sponsored by: Innova
Single Din Fascia Insert.
Old Nov 5, 2006 | 04:13 PM
Essex Boy's Avatar
Essex Boy
7th Gear
Default Single Din Fascia Insert.
Hi to everyone, as I'm a newbie.
I've been searching and reading the forum for quite a while, and if poss would appreciate if you could answer a few q's for me.I have been searching the FAQ audioi section, but to be quite honest, i'm getting a bit lost as to what I can and can't do with the vette audio set up.???
I'm in the uk and just bought a '91 C4. There is no Bose stereo in the vehicle, just a hole where it should be, and the leads which appear to go to the right behind the dash. I'm assuming this goes to the module that I've been reading about. I would like to fit a new single din HU, but I am unsure of which part, I should be purchasing to be able to fill the hole and fit a single din in the remaining space.Hope that makes sense.
I've seen both of these on ebay and still not sure if one or both are suitable for fitment for my requirements.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
http://cgi.ebay.co.uk/METRA-INSTALL-...QQcmdZViewItem
Any advice or help would be appreciated.
I have no problem using the existing bose speakers, so I understand there is some kind of module which will allow me to still use them, am I correct??. If so, would it be possible for someone to help me, as to which type/sort of module I should be buying in order to run the bose speakers, as I'll obviously have to purchase from somewhere who will ship to the uk. Can I assume, I can use the same speaker wiring?
Thanks for any help.
regards
Essex Boy.
Old Nov 6, 2006 | 09:52 AM
DPG's Avatar
DPG
St. Jude Donor '06
contact vrum vrum for a faceplate. They look great. Sorry i have no info on the adapter you will need
Old Nov 7, 2006 | 04:28 AM
Essex Boy's Avatar
Essex Boy
7th Gear
thanks for that, very much appreciated
I've just realised that vrum vrum is a user name, I was thinking it was a company. Anyway, I've done a search and found the details
thanks again for the reply
To Single Din Fascia Insert.
