Ppi Dcx 1000.4
Key Features
Amplifier Type Multi Channels
Bridgable Bridgable
Performance
Frequency Response 10 Hz - 50000 Hz
Signal to Noise Ratio 100 dB
THD at Rated RMS Power 0.08 %
Dimensions
Width 23.63 in.
Depth 10.5 in.
Height 2.75 in.
Miscellaneous
MPN dcx1000.4
More Information
Four new multi-channel DCX amplifiers give you limitless system configuration potential. The heart of this uniquely configurable design is the legendary TC-X crossover. This flexible, highly accurate built-in active crossover allows complete internal and external control of frequencies from 30-4KHz in high-pass, low-pass, or full-range configurations. This absolute control is integrated with four and five channel class AB output stages that range from 300 to a stellar 1,000 watts mobile power delivery has never been more pure and precise.
Fully regulated design for guaranteed power delivery Flexible TC-X crossover with configurable line out High-voltage input capability with selectable 12dB attenuation Mixed mono/stereo operation 2 ohm stereo stable Q Bass Plus 125 watts x 4 at 4 ohm 250 watts x 4 at 2 ohm 500 watts x 2 at 4 ohm bridged output S/N ratio: >100dB Frequency response: 10Hz-50kHz Damping factor: >300 Crossover slope: 2-way 30Hz-4kHz 12dB/octave 23-5/8" x 10-1/2" x 2-3/4"
