Sponsored by: Innova
Infinity: 6012si or 6012i
Old Dec 12, 2006 | 05:08 PM
cjcvette's Avatar
cjcvette
Default Infinity: 6012si or 6012i
I have a 99 coupe and I am going to replace the speakers in the back. Will 6012i speakers fit or do I need the 6012si?
As a side note, I will be installing 3012sf in the front at the same time.
Old Dec 12, 2006 | 06:05 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
depth is tight I know that, I would go with the SI just to be safe its basically the same speaker
Old Dec 20, 2006 | 01:36 PM
cjcvette's Avatar
cjcvette
I ended up with the SI, which fit no problem. The only difference (according to the instructions) is that the I model allows you to rotate and change the direction of the tweeter, whereas the SI model has a fixed tweeter.
After break in they do sound better than the bose. Now, on to the fronts...
Old Dec 22, 2006 | 12:08 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I ran the si's - sounded sweet
To Infinity: 6012si or 6012i
