? on Door speaker replacement 1998 firebird ws6
Here's the info from the service manual:
Remove the accessory switch panel.
Remove the inside handle bezel. Refer to Handle Bezel Replacement - Inside.
Remove the window regulator handle and spacer, if equipped.
Remove the outside rearview mirror bezel. Refer to Mirror Replacement .
Remove the side door armrest bolts (2).
Remove the front side door trim from the door inner panel.
Pull the side door trim up from the door, making sure the hooks release from the holes in the door inner.
Disconnect the door speaker electrical connectors.
Remove the courtesy lamp socket from the door trim.
I've been helping a buddy with an '02 Z28 do his system, though it was a couple of months ago when we pulled the door panels off. It was mostly lift up plastic, pull out bolts and then lift the door panel off. The Z has male hard plastic hooks that clip into the door. Lift and work the panel slowly so you don't break those male connectors on the door panel, I believe they're molded in.
