So far I have 6 layers of liquid, and 1 layer of sheet damping. This is THICK, and probably about as thick as I can go, but... The panel is still really bad. It has a nice low thunk, but my IDMAX will vibrate this thing like a reed, I know it.
And what's worse, is the section behind the seats that I haven't even started with...
This car is going to flex like a balloon if I don't do something...
Has anyone affixed balsa wood to the bad sections? I know the floors are very stiff, and GM sandwiched balsa in. My thought is to apply liquid damper, a layer of balsa, then a layer of sheet damping. This might allow a combination of damping and barrier that could make these panels "not so bad."
But I'd need to find 1/8" balsa wood sheets, which I'm having trouble finding...
Has anyone done something similar to this? Maybe something better than balsa? Cork?
Furthermore,
Wouldn't a cork gasket under the speaker rim, as well as a cork gasket around the MDF speaker mount reduce vibration that the door panel is subject to? This stuff is probably better than using dynamt type material for such an application. Though there has to be a reason people aren't using it.
There is a book, "101 Projects for your C4" in which the author recommends putting cork under the rugs in the rear of a coupe to reduce the sound levels and make the car quieter. I think it would work well. Have you thought about adding a Crazy Cowboy kit over the liquid sound deadening?
I have my eye on some sheets of adhesive closed cell foam (Same thing but cheaper) but the Cork would work to reduce vibration and act as a noise barrier. At least, according to the cork websites' information sections.
Hi kale, I agree, these fiberglass panels are thin. I think you'd be better off starting where the factory left off. Scuff the panels with 24 or 36 grit use epoxy resin and fibrglass mat. 2 layers of mat and epoxy resin will give you more stiffness than the balsa. You could go even further by getting some 1/8 or 1/4" thick strips of fiberglass and put them on top of the mat between the ridges.
I think the liquid stuff did an OK job of stiffening, for what it is. It dries inflexible, which is one of the reasons I like it over dynamat type material.
EG no one will ever call "under engineered" on your projects
The cork is acting as a decoupler I am guessing? I just am not sure that wood, which resonates in its own way especially at that thickness is the answer. I guess if you went and decoupled each layer (IE factory glass > liquid deadener > "dynamat" > closed cell > wood > dynamat? )
Have pics of the install yet? Kinda curious what it looks like ... might be easier to help
is the idmax gonna be in a box? what im thinking is that with the weight of the sub and box, that could be enough mass in itself to reduce vibrations. Am I thinking right? or am i just not anywhere near the right direction. I also remember that once th ecarpet is all back on. it does a descent job of absorbing vibrations.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I removed my gas tanks so I could eDead v3 plus 1SE on both sides of the panels behind the seats. I covered the entire bottom of my car in eDead v3 (liquid)
why am i not surprised I was thinking about doing that too actually. But i just havent gone through with it yet too many idea and plans, but no budget to do it
I'm planning on painting the bottom under the seats with v3 as well.. .curious how its going to hold up, though. I'm definitely removing the mufflers and getting the "bulges" since I didnt do much damper on the inside of them.
Edesign said not to apply to exterior surfaces, so the worst it can do is fall off, I guess.
Probably better to use an underspray material than the edead .. or maybe edead then some sort of underspray specific, or bedliner type spray for the outside.
Put a 1" face (sub mount) on that box bro .. its gonna need it
I used v1SE first then v3 over that - so I figure if v3 falls or flakes off, v1SE will still be there
I have used the products from Second Skin and been very impressed. http://www.secondskinaudio.com/cgi-bin/index.cgi They have a three step process. I have used the Damplifier Pro (plus a speaker kit) and the Overkill Pro, but nothing from the Silencer series. I have the Crazy Cowboy Kit in and then the Overkill Pro. Mainly because of weight issues, I haven't put down dampener over the entire car. I have the Damp Pro in the doors and plan on covering it with Overkill, just haven't done it. The Crazy Cowboy Kit and the Overkill Pro are pretty light comparatively, so that is what is in the rest of the car. The front stage sounds great. No real rattles except the trunk lid and the mirror with hard base hits. You can hardly hear the stereo outside of the car with the doors closed. If the rattles are from distinct frequencies then the different products designed to kill those freqs might be helpful. Second Skin has a forum that might be helpful also http://www.secondskinaudio.com/forums/index.php There are some pretty knowledgeable guys on it, certainly more than I; and the owner is quite helpful as well.
