Sponsored by: Innova
Basic C4 Stereo Replacement?!
Old Dec 20, 2006 | 05:31 PM
TUNED87vette's Avatar
TUNED87vette
Default Basic C4 Stereo Replacement?!
I am really into car audio, and my daily driver already has around $4000 of equipment to satisfy my needs. However, I am replacing the front stage and will have an extra pair of 5.25" Eclipse point source. I think that these will mount in the front of my 87 (will pull the grills and do some measuring), but can anyone confirm?
Those take a lot of power, so I will need a new headunit to replace the crappy Bose tape deck. Is this a standard double-din size? Would the Alpine IVA-W200 fit? Do they make a harness that's easy for this car? I want to bypass the Bose amps, and would like to avoid running all new wires (although I can).
I also have an extra set of 5x7's that I pulled from the rear of my ford, and would like to know if these will fit? I could definately find some 6x9's or 6.5's that would fill in the rear if not.
I don't want to add any weight and just overcoming the motor sound is my main concern.
Help with any of the above questions is much appreciated!
Old Dec 20, 2006 | 06:20 PM
Kale's Avatar
Kale
Fronts will fit up to 6.5 without having to cut anything.
rears are 6x9s, youll need to create a baffle
head unit is 1.5 din
All of this stuff is in the C4 faq sticky...
Might want to read through it.
