Sponsored by: Innova
No Power
Old Sep 29, 2001 | 10:56 AM
Bradley33's Avatar
Bradley33
Default No Power
Not really a vette question, but I'm putting a new radio in my Neon and I'm having trouble
I wired in the harnesses and plugged the radio into the car, I spliced in the ground and the cd player gave that little whirring sound so I know it was gettting juice.
However when I started the car and pushed the power button the radio didn't work :(
That's sort of the quick version of the story, anyone see anything that might be obviously wrong?
Old Sep 29, 2001 | 06:23 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: No Power (Bradley33)
Radios have two power wires. Check both to make sure you have power to both wires. One will be constant, the other igntion. You could have one and not the other and get limited functions like the one you described. If the unit is already installed, check the fuses first(both). No point in tearing it apart if it is a fuse.
92TripleBlack :cheers:
Old Oct 1, 2001 | 09:32 AM
Bradley33's Avatar
Bradley33
Both power wires are hooked and I've checked the fuses on both the car and the radio.
I'm beginning to think about redeeming that warranty I have.
It worked a few days ago though in a differnt car ?????
To No Power
