Sponsored by: Innova
C-5 Speakers
Old Oct 1, 2001 | 12:18 AM
vette dreams's Avatar
vette dreams
Default C-5 Speakers
Hey guys, what size speakers does a 2000 coupe have. What size speaker is everybody replacing them with. Thanks in advance. :D
Old Oct 1, 2001 | 01:53 AM
Sam Lin's Avatar
Sam Lin
Default Re: C-5 Speakers (vette dreams)
6.5" all around. I recommend Focal over anything, then Diamond Audio with silk dome tweeters, then Infinity Kappa or MB Quart.
Sam
Old Oct 1, 2001 | 09:34 AM
99HT's Avatar
99HT
Default Re: C-5 Speakers (Sam Lin)
The Bose system has six speakers. The Bose Twiddlers, two 3.5" in the door and two 6.5" (coupe) 5.25" (vert, FRC) in the rear, are powered by the head unit internal 4 ch power amp. Bose Twiddlers are mid/high-frequency speakers. There are no true tweeters in the C5 Bose system.
The two 8" reverse cone Bose sub-woofer speakers in the doors have two sub-woofer power amps near them in the door. These two amps are the only external power amps in the C5 Bose system.
Most GM vehicle do not use true 6.5" speakers. They are really 6.75". Be sure to take the speakers with you to get a substitute.
The Bose twiddlers are fed only frequencies above 1khz. Unless you replace the BSP and HU poweramp, speakers with good bass are a waste of money.
To C-5 Speakers
