Sponsored by: Innova
Amp Power and Ground
Old Dec 29, 2006 | 01:51 PM
easyasone2three's Avatar
easyasone2three
Default Amp Power and Ground
Laying out my wiring. Running the 4G back to where I am mounting my amps and using a Raptor Power Distribution Block to go to 8G to each amp. Same thing for the amp ground.
I stripped about 1/2 inch of 4G to insert into power block but I don't think it is right that way.
Question:
Will the set screw in the power block penetrate the 4G shield for a good contact or do I need to strip some shield and tin the end with solder? If so should I just use rosin core?
Old Dec 29, 2006 | 02:23 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
you stip the insulation off the 4ga stick it in then lock the allen headdown onto the bare strands... this is the standardized way of doin it
Old Dec 29, 2006 | 02:32 PM
easyasone2three
Allrightythen!
My whole family tells me I try to make things too complicated. Sorry, it's the way I am.
Thanks Pentavolvo.
Old Dec 29, 2006 | 02:48 PM
pentavolvo's Avatar
pentavolvo
its called doing it right the first time and you wanted to make sure u did
Old Dec 29, 2006 | 11:29 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
....otherwise you get the "measure twice, cut once, swear repeatedly" syndrome
To Amp Power and Ground
