(Dialup go get a snack)I finally finished installing navigaton system
#41
, so I should not have any problems fitting a player that is 178x100x160mm. Did you have to modify anything for it to fit? If so, how much?
Edit: I'm waiting on this one to be released.
http://www.jvc.com/press/index.jsp?i...2&CategoryID=4
#42
you'll probably have to cut out the plastic backing behind the radio like i did. it isn't too big of a deal to do. Took only a couple minutes with a rotozip. cutting it give plenty of room for wires and the cooling fan.
#44
Thanks for the info and pictures.
#46
I've never actually looked behind the radio in the Vette before. In a few other installs I have done, I added extra cooling fans behind the radio. Does it look like there would be a need for that. I'd imagine it can get pretty hot in there at times. I don't think I'll have any issues installing as long as the fit is somewhat close. I bought an extra front console radio bezzel just for this install. I'm also going to paint it with something more durable and try to match the original look the best I can.
#47
1 Post
I see that you live in Levittown and just by chance, I'll be in Levittown in two weeks visiting my brother. Do you think you may be able to give me a personal showing? You did a great job and I'd like, if possible, to see it up close.
#48
Excellent job-I use a tomtom because I use it for different cars but your install looks like a factory option.You should do this work as a second profession
BTW I also have a black 95 vert
#50
INCREDIBLE! That is exactly what I want to do in my '96. If you don't mind, I may send you a couple PMs down the road when I get around to this project to ask for your assistance (advice, actually). I've never done car audio before, but if the system is going to set me back $2k, I'm going to try like hell to install it myself before paying someone else to do so!
#51
How was the rest of the install (i.e., all the stuff other than the HU)? It's my understanding that when doing stereo upgrades to a C4, you basically have to do a complete tear-out of the old stuff, right down to the wires, and start fresh.
Sounds scary....
Sounds scary....
