Sponsored by: Innova
C5 Speaker wires
Old Jan 18, 2007 | 10:53 AM
the_teapot's Avatar
the_teapot
St. Jude Donor '10
Default C5 Speaker wires
I have a 2003 C5 Z06 & plan on upgrading the 3.5" front speakers & 5.25 " rear speakers with some 2-way JL Audio speakers. I had no luck searching the forum to ascertain which speaker wires are the (+) and (-) in the factory connector. Since the stock speakers attach via a connector/harness, does anyone know which wire is the (+) and which is the (-) for the front & rear speakers? I plan on simply splicing some adapters to hook up the new speakers whenever I get them. Thanks a bunch.
Old Jan 18, 2007 | 11:24 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
You should be able to get the "plug in" harness adapters from any good sized audio shop. Plug the adapters into the car's speaker harness, and the other end should have the correct terminals for your aftermarket speakers.
Old Jan 18, 2007 | 12:26 PM
DPG's Avatar
DPG
St. Jude Donor '06
its somehwere here its been discussed before but i dont remember what the name of the thread was
Old Jan 18, 2007 | 12:29 PM
DPG's Avatar
DPG
St. Jude Donor '06
http://forums.corvetteforum.com/show...t=speaker+wire
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
For the rear Right
+ Dark Blue - Light Blue
Rear Left
+ Brown -Yellow
For the front I dont exactly remember what it is for some reason I think its same colors on each side basically what you can do is look at the back of the stock speakers its plry market + or - and jsut follow that coresponding but if its not unhook the stock one and hook a 9 volt battery up to it it will either pop out or pull in, you want it to pop out then follow the designation on the battery the side the positive is hooked upto is positive, etc. I hope this makes sense.
Otherwise the info I have which may not correspont at all is
Frt Right
+ Lt Green -Dk Green
Frt Left
+Tan -Grey
Old Jan 18, 2007 | 02:25 PM
the_teapot's Avatar
the_teapot
St. Jude Donor '10
Thanks for the info, I appreciate the help!
Old Jan 18, 2007 | 03:50 PM
pentavolvo's Avatar
pentavolvo
please confirm or post the wire colors for the front speakers so i can add it to the FAQ for all memebers
Old Jan 20, 2007 | 04:43 PM
the_teapot's Avatar
the_teapot
St. Jude Donor '10
I'll update (with pics if I remember) after I get my speakers & do the install. Hope to see them sometime this week (Jan 22-26).
To C5 Speaker wires
