Sponsored by: Innova
AMP Facade (cover) Help needed
Old Jan 21, 2007 | 09:59 PM
AP's Avatar
AP
Plexi all the way ..
Old Jan 21, 2007 | 10:26 PM
-=Jeff=-'s Avatar
-=Jeff=-
Originally Posted by TheRadioFlyer
Love the window idea. If you really want to be creative, you could do a little etching on the plexi and the LEDs would really set it off.
Home depot offers 1/2" MDF if 3/4" is too heavy for your application.
Cooling fans are a HIGHLY RECCOMENDED. the good news is that fans smaller then 70mm draw so little current you can run them off the run on lead without a relay and run the ground to your amp's ground.
I don't have the steady hand for the etching..
The cover will be 3/4" thick.. I was thinking of 1/4 plexi for strength as well as 1/4 on top and bottom to sandwich the plexi.
Old Jan 22, 2007 | 09:22 PM
-=Jeff=-'s Avatar
-=Jeff=-
Man,
this cover is going to get expensive real fast.
I found a guy that will do the Emblem out of Acrylic for $30 if he does the design in a CAD program.. $20 if I supply the CAD drawing
Then the Plexi for the cover, and fans and Cold Cathodes (it will be easier then LEDs.. Although the Cold Cathodes can be added later..
Old Jan 22, 2007 | 09:45 PM
scott_fx's Avatar
scott_fx
you know; if you're not going to be side lighting it, i wouldn't even bother with the etching go online and find a vinyl place that has c4 logo's and just have him cut out the emblem from some frosted vinyl and be done with it.
Old Jan 22, 2007 | 09:47 PM
-=Jeff=-'s Avatar
-=Jeff=-
Emblem is going under the carpet int he center of the rack..
Windows will be plain (except lighted later)
Old Jan 22, 2007 | 09:56 PM
scott_fx's Avatar
scott_fx
woops..that is right. sorry :-( you through me off when you said 'cut out of acryllic'
hmmm... too bad you don't have a c5, i'd go in on that with you and maybe it'd cut costs some.
Old Jan 22, 2007 | 10:15 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The procedure would be rather simple. Find a kinkos with a large copier and enlarge your picture. Then trace it with an engraver on to the plexi.
What i could do (depending on the size of the actual etching) is get some plexi and etch the design for you. (i'd have to charge for the plexi, shipping and such) PM me the dimentions and design and we can talk.
you can see some of my etching work on this thread:
http://forums.corvetteforum.com/show....php?t=1577942
Old Jan 22, 2007 | 10:28 PM
scott_fx's Avatar
scott_fx
heh...you were fooled like me
he needs it cut out of wood or some material so that he can glue it down before carpeting. after that he'll carpet it and it'll come through as a raised logo.
Old Jan 22, 2007 | 10:55 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
oh...(bleep) I think i saw a commercial for a craftsman computer router that looks like a printer that can rout just about anything you program it to. (including compound curve 3D routing)
the downside is that it costs $2100
Old Jan 22, 2007 | 11:11 PM
-=Jeff=-'s Avatar
-=Jeff=-
Yep, you got it.. for the $20 that is a great price.. $30 it he does it in CAD
Old Jan 22, 2007 | 11:19 PM
scott_fx's Avatar
scott_fx
yeah, i want one of those badly!
Old Jan 22, 2007 | 11:26 PM
DPG's Avatar
DPG
St. Jude Donor '06
i read some reviews on it both good and bad.
