Sponsored by: Innova
AMP Facade (cover) Help needed
Old Jan 20, 2007 | 11:56 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default AMP Facade (cover) Help needed
I am at the point that I need to decide how to do my amp rack cover.
here is the concerned area:
it will be flush with the door on the left of the picture. I am thinking of making a window for each amp, either open for cooling or under plexi along with fans for cooling. if I skip the plexi and make the open spot, there will be a vented cover using grill cloth. even with the Plexi I will make cover so the plexi is not always seen
So what would you do??
Lastly if I do Plexi, I was thinking of red LEDs to light up the plexi, but how far apart should they be spaced?
Old Jan 20, 2007 | 01:36 PM
DPG's Avatar
DPG
St. Jude Donor '06
im thinkin plexi would be the coolest. scott and some others should know how far to space the leds out for the lighting. it would be cool to see the ed amps logos through plexi all lit up
Old Jan 20, 2007 | 02:22 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
im with dave on this plexi all the way
Old Jan 20, 2007 | 02:40 PM
-=Jeff=-'s Avatar
-=Jeff=-
So how big of a window?
Old Jan 20, 2007 | 05:00 PM
-=Jeff=-'s Avatar
-=Jeff=-
something like this?
Or should the plexi area be bigger??
Cardboard is great for these mock ups
Old Jan 20, 2007 | 05:09 PM
DPG's Avatar
DPG
St. Jude Donor '06
looks good to me jeff
Old Jan 20, 2007 | 06:55 PM
VinceC5's Avatar
VinceC5
Don't forget the big C4 logo right in the middle.
Looking good.
Old Jan 20, 2007 | 07:11 PM
pentavolvo's Avatar
pentavolvo
lookin sexy man... Jeff are u seriously up for helpin me do O2s and putting my off road hpipe back on my car in liek 1.5-2 mths
Old Jan 20, 2007 | 07:12 PM
bogus's Avatar
bogus
that would be trick.
I assume that the remaining cover would be MDF, right? Get a pattern and cut a C4 logo into the MDF and carpet in, as long as it's thick enough.
Or, get one cut and glue it then carpet over, to make it raised.
Old Jan 20, 2007 | 08:10 PM
-=Jeff=-'s Avatar
-=Jeff=-
I was hoping NOT to use MDF, as it is heavy. but I may end up with that.. the cover will be 3/4" thick , but with doing Plexi I will have three 1/4 pieces glued
but the middle section will be hollow, especially if I use LEDs on the plexi..
I only got to the cardboard stage though so far
Penta,
As long as my vette is movable and I can get the stang on my Kwiklift it should not be a problem.. Beer and Pizza will be on you though.. LOL
Old Jan 20, 2007 | 08:47 PM
pentavolvo's Avatar
pentavolvo
haha cool cool i can handle beer and pizza... im hopin we can get this hpipe to seal up on there im gonna try and get it straight next time im home seeing as it has a small offset in it othrewise i might just call the guy who did some of my other work for a good cost, and have him do it since im gettin lazy and he has a full shop
Old Jan 20, 2007 | 09:18 PM
scott_fx's Avatar
scott_fx
i think i'm the last person to be giving advice on amp rack design :-( ... but i think id like to see what the window look like a bit larger.
when you say you're going to use led to light up the plexi, does taht mean you're going to etch something into the covers of the plexi and you want to side light it? or did you actually mean that you just want some led's in there to light up the amp under the plexi?
one idea i have is to acutally mount led's under the amps, raise the amps up just a hair (~1/8") with some standoffs or even a couple washers. and have the amp look like it's floating and glowing. then get some white (or orange) led's and light up the box from the top
Old Jan 20, 2007 | 09:39 PM
-=Jeff=-'s Avatar
-=Jeff=-
This is what I was thinking
As for raisng the amps, I am not going to go that far yet.. I want to keeo it some what simple..
As for a larger window I can go larger on the sides of the rack, but not the front to back. most has to do with intergrating the rack cover with the Storage doors..
Old Jan 20, 2007 | 10:04 PM
scott_fx's Avatar
scott_fx
i know you want to save weight but cardboard wont cut it
Old Jan 20, 2007 | 10:30 PM
-=Jeff=-'s Avatar
-=Jeff=-
Any Idea where I might be able to get this done? or order one?
Old Jan 20, 2007 | 10:49 PM
scott_fx's Avatar
scott_fx
i bet elemental designs would cut it for you
Old Jan 21, 2007 | 03:07 AM
bogus's Avatar
bogus
gee, it would be neato, but I donno who is gonna cut it.
a thought, if you can get a shop to cut a vinyl decal, you could cut it out with a scroll saw. It doesn't have to be PERFECT, just very nice, cause the carpet would cover up any glitches.
To AMP Facade (cover) Help needed
Old Jan 21, 2007 | 09:58 AM
-=Jeff=-'s Avatar
-=Jeff=-
I need for find a nice Jpeg of a c4 emblem
there is emachineshop.com that can do it as it looks
Old Jan 21, 2007 | 01:33 PM
scott_fx's Avatar
scott_fx
also check out the diycnc forums. i bet a some guys would do it for you for a few bucks.
Old Jan 21, 2007 | 09:21 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Love the window idea. If you really want to be creative, you could do a little etching on the plexi and the LEDs would really set it off.
Home depot offers 1/2" MDF if 3/4" is too heavy for your application.
Cooling fans are a HIGHLY RECCOMENDED. the good news is that fans smaller then 70mm draw so little current you can run them off the run on lead without a relay and run the ground to your amp's ground.
