Sponsored by: Innova
Will this fit? C4
Old Feb 10, 2007 | 11:17 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Will this fit? C4
with no cutting required or extensive mods required?
The dimensions given are:
Dimensions
(chassis) .................. 7-3/4 (W) ´ 3-1/8 (H) ´ 5-3/8 (D) in
(nose) ...................... 7-1/2 (W) ´ 2-7/8 (H) ´ 7/8 (D) in
Pioneer
I know I'll have to remove or at least bypass the receiver.
The stock radio died, suffers what was an intermittent (that now seems permanent ) power loss for some reason.
If I can't locate the problem I'd like to go with a direct fit replacement until I put the stock system back in.
Old Feb 11, 2007 | 12:41 AM
bogus's Avatar
bogus
Most single or double DIN head units will fit.
You will have to bypass the receiver. It is the actual power source, either Bose or Delco...
Don't bother with using speaker adaptors if you have Bose... get new speakers and run fresh wire, you will thank me.
Old Feb 11, 2007 | 12:56 AM
Blue 92's Avatar
Blue 92
Thanks. This is a 1.5 DIN. Standard Delco so no Bose stuff to worry about.
To Will this fit? C4
