Sponsored by: Innova
Profile Calfornia CW10 Sub
Old Feb 18, 2007 | 03:49 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Profile Calfornia CW10 Sub
Features Blue-Mica Injection Molded Cone, Rubber Surround, 40 oz. Magnet, 2" Four Layer Kapton Voice Coil, Impedance 4 Ohm, Extended Vented Back Plate, Frequency Response 19 Hz - 1.2 KHz, Sensitivity 89 dB, Power Handling 500W Max, 1 Year Warranty.
How do these sound? Anyone have one or heard one?
Old Feb 18, 2007 | 03:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
back when circuit city carried profile they had a special on a cheap profile sub where you bought any amp you got 2 free, lets just say it wasnt too hot of a sub. the fosgate would even be better then that
Old Feb 18, 2007 | 04:16 PM
screw991le's Avatar
screw991le
What makes it a bad speaker? I just want to add 2 10" subs to my stock bose system. Is the quality ok?
Old Feb 18, 2007 | 04:23 PM
pentavolvo's Avatar
pentavolvo
its just not a well built speaker, very sloppy sounding. you are spending money on a box, wiring, and an amp might as well get a half way decent sub or subs.
this is a nice cheap 12 http://sonicelectronix.com/item_7494.html actually a really nice speaker. you would want the 400sx then instead of msx.
for 2 10s http://sonicelectronix.com/item_1721.html these are actually pretty nice ive used the 12" version in 3 diff cars all with good results
generally 1 12 will be less money then 2 10s and output will be the same generally speaking. you best bet IMO is the 12" eclipse or this mtx http://sonicelectronix.com/item_8293.html both good speakers
Old Feb 18, 2007 | 04:26 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Yeah, those phoenix Gold subs are nice! I am kinda partial to the ZR10's. I think he is going with some infinity 1050's which should sound really good also!
Old Feb 18, 2007 | 04:33 PM
screw991le's Avatar
screw991le
I am going with the 1050w
Old Feb 18, 2007 | 04:38 PM
pentavolvo's Avatar
pentavolvo
are you doing 1 or 2... i just want to makesure you match the amp to the subs etc
Old Feb 18, 2007 | 04:42 PM
screw991le's Avatar
screw991le
2 - 1050w
Old Feb 18, 2007 | 04:46 PM
pentavolvo's Avatar
pentavolvo
ok go with the 400msx or if you can swing the extra 20 dollars the ca600m swings another 125-150 watts rms which would push those 2 10s even harder.
IMO it would be cheaper to just go with a single 12" but its all up to you
Old Feb 18, 2007 | 04:51 PM
screw991le's Avatar
screw991le
I got 2 Infinity 1050w's 10" for $100.
See my other post for the parts list update.
I also decided to keep the rear speakers, but changing them out.
To Profile Calfornia CW10 Sub
