Sponsored by: Innova
Amp - Sub wiring question.
Old Feb 19, 2007 | 10:11 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Amp - Sub wiring question.
I plan on running 2 10" single voil coil subs (4ohms ea)(rated at 250rms @ 4ohms) to a MONO amp.
Question is the amp is rated as follows :
RMS Output Power (4 Ohms) 200W x 1
RMS Output Power (2 Ohms) 300W x 1
If I run the 2 subs in Parallel do both of speakers get 300 watts each or does it drop in half due to the 2 speakers splitting the 300watts.
Old Feb 19, 2007 | 10:30 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
it splits so each sub gets 150
screw991le's Avatar
screw991le
To Amp - Sub wiring question.
