Sponsored by: Innova
Audio Help.....
Old Mar 1, 2007 | 08:39 PM
69any1's Avatar
69any1
Default Audio Help.....
THIS SUCKS...... I am usually very good at the audio part of things but now i feel stupid... When i disconnect the radio that was in there it worked fine.. I unpluged all the wires and rehooked everything up with the new harness,, The cd play WONT come on.. I checked the fuse and its fine... I tried using a test lite but im not sure its working right.. if i touch a live wire it sparks... NOw just before i hooked the new cd player up i tried testing a wire and it arced some. I tired touching it again and nothing.. I have 2 pictures if u can make any of it out... HELP ME PLEASE...
Old Mar 1, 2007 | 08:44 PM
spedaleden's Avatar
spedaleden
Get a test light that works. Don't be touching wires to ground to see if they spark. That is NOT the way to check for power. I am sure you blew the fuse in the fuse panel. It should be a 10amp
Old Mar 1, 2007 | 08:46 PM
69any1's Avatar
69any1
I wasnt touching them to ground.. i grounded my test light touched the live wire with my test lite and it arced
Old Mar 1, 2007 | 09:22 PM
Durango_Boy's Avatar
Durango_Boy
Get a multi meter, instead of a test light. No chance of arcing that way.
You only need three wires to get it hooked up right. Most head units follow the same standards.
Yellow - Constant 12V (BAT)
Red - Switched 12V (IGN)
Black - Good Solid Ground
You just have to determine which of the factory wires is what when tracing them. Start with the IGN on, and test for any wires that have 12V. Then, switch the key off, and test the same wires looking for the ones that switched off and the ones that are still 12V.
I would suggest making your own ground but that's just my background talking and I don't always trust harness grounds. You can get loops and interference.
Old Mar 1, 2007 | 09:26 PM
69any1's Avatar
69any1
I am driving the vette to work tomorrow and i will check it there.. I just swapped out wire for wire from the old harness.. i am gonna go out in the garage and check it again. its driving me NUTS
i will report back
Old Mar 2, 2007 | 08:05 AM
69any1's Avatar
69any1
Default Update!!!
Im embarassed to report, but when i pulled out the fuse the other night.. The way its labled its a tad confussing. I pulled out the fuse below the radio... I put a volt meter on the fuse block and all fired up except one.. THE RADIO.... Im
Old Mar 2, 2007 | 08:11 AM
spedaleden's Avatar
spedaleden
So the car is supplying 12 volts but the radio is not working. I think thats what your saying?
Put 12 volts to the power lead of the radio but connect power so the fuse is not in line. If the radio has a hot all the time usually a yellow or orange wire connect it to 12 volts also, connect ground to the radio and see if the radio powers up. Sometimes a fuse can look good but it is bad or the fuse holder may be bad.
Old Mar 2, 2007 | 08:25 AM
Durango_Boy
I have seen bad head units right out of the box too, so bench checking it is always a good idea.
Old Mar 2, 2007 | 09:15 AM
69any1's Avatar
69any1
I was thinking the radio might be bad.. but when i pulled out what i thought was the radio fuse.. it was a good fuse.. but i pulled the wrong fuse.. the REAL radio fuse was blown.. that was the only terminal i wasnt getting anythign from. I just went and bought another one 10 amp. this should be my problem!! sorry for being confusing!!
Old Mar 2, 2007 | 05:19 PM
Durango_Boy
Glad to hear the head unit plays...good luck find the 12V constant for memory.
Old Mar 2, 2007 | 06:16 PM
spedaleden's Avatar
spedaleden
oh, BTW I love the color of your car.
To Audio Help.....
