Sponsored by: Innova
C6 Speaker Wire Colors
Old Mar 2, 2007 | 12:44 PM
JJL64's Avatar
JJL64
Default C6 Speaker Wire Colors
Does any one know what the factory possitive and negative speaker wire colors are for the rear, 3.5 doors and center for a non-Bose convertible without Nav? I want to upgrade my speakers this weekend and cannot seem to find anyone who lists a compatible speaker wire harness for the C6 yet.
I am new to the forum and any help would be appreciated!
Old Mar 2, 2007 | 01:16 PM
speedmd's Avatar
speedmd
I'm in the process of upgrading my speakers (1LT, no bose, no nav), and I think you will find your time is better spent running new wires. The factory HU ran to a POS delphi amp in the passenger wheel well and the wiring is beyond sane.
Hopefully this will help you avoid some pain. http://forums.corvetteforum.com/show....php?t=1630977
Old Mar 2, 2007 | 01:24 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
While speedmd's advice is good if you're installing a new amp or head unit if all you're doing is a speaker swap there's no benefit to running new wires.
If I remember correctly.. the darker wire of the pair for each speaker is always positive.
Old Mar 2, 2007 | 01:34 PM
JJL64's Avatar
JJL64
Thanks. All I want to do is swap the speakers out without a new HU or new wires. I could pick-up a Service Manual, but don't want to spend the $150.
Thanks for the info. I'll give it a try.
Old Mar 2, 2007 | 01:37 PM
rothchilds's Avatar
rothchilds
he is correct. usually GM does the same color for each speaker, one lighter and one darker. Contrary to all logic, the darker color is positive
Old Mar 2, 2007 | 02:52 PM
BEZ06's Avatar
BEZ06
Sounds like the other posts about darker wire = + are good advice.
Here's a link to a thread about replacing the door speakers. Post# 9 has the polarity of the speakers in the doors:
http://forums.corvetteforum.com/show....php?t=1633971
Bob
Old Mar 2, 2007 | 04:35 PM
tloon's Avatar
tloon
Right front door orange positive, left front door dark blue pos, left rear speakers yellow is negative, front center light blue is negative.
Old Mar 2, 2007 | 04:56 PM
JJL64's Avatar
JJL64
Thanks, that helps a lot. Do you know about the right rear? The two wires are light blue and dark blue.
Thanks!!!
Old Mar 2, 2007 | 05:17 PM
tloon's Avatar
tloon
Thanks!!!
Dark blue pos. This is on an 07
Old Mar 3, 2007 | 08:12 AM
JJL64's Avatar
JJL64
Mine is an '06, but I would assume that the wiring would be the same.
Thanks!!!
Old Mar 3, 2007 | 09:40 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
yeah should be same, otherwise darker wire is positive
To C6 Speaker Wire Colors
