i installed a few of the eclipse amps at work no complaints at all very solid amps, to bad i dont get my 50% off msrp still i coulda hooked u up
Do they sound as good as AB amps? Thats my only real concern.
Two 30 amp fuses on a 100x2 class d...
my 100x2 class A is two 20 amp fuses... and its less efficient.
Do you think these amps are underrated?
Orion also looks good... 125x2 for 240, but im skeptical because amps that list their max power rating on their body are usually junk. SNR is 77db, I know anything less than 90 is audible...
so you only get noise when you plug the head unit into the amp? Is it a busted ground in your head unit? have you tried grounding the rca to the amp ground?
edit: nevermind, you posted before i hit submit.
I wouldn't be conserned about the amp humming *yet*. the amp may need a signal to behave (have heard of this before). I guess as a first line of defense i would try to ground the rca to the amp ground and see what you get
Stereo connected as normal. (HU to RCAS, RCAS to amp)
REsult: Crackle
Stereo not connected to RCAs. RCAS still connected to amp:
Result: Crackle
Head phones connected directly to head unit.
Result: Crackle
Head unit connected with different RCAS ran down center of vehicle:
REsult: Craclke:
RCAs ran down center of vehicle, with ipod directly as source
result: No crackle
So, the only time i dont get crackle, is when the head unit is not plugged in AND when im not using the RCA run that goes down the left side of the car.
IF i used head unit and bypass rca run, I still get crackle.
(power is ran down the right side if anyone is curious)
So this must be a noise simply "present" in my electrical system. The ran RCAs act as antennae, the HEad unit acts as an antennae, but not the Stinger RCAS I ran down the center. and not the amp itself.
u said when the new rcas were ran down the middle and u plugged the ipod in you got no noise correct?
i would try using those rca's plugging them into the headunit and running a small wire from the outer ring on the rca behind the radio to the radio ground and see if it eliminates the noise.
The headphones to headunit crackling tells me you have blown preouts on the radio, which possiably could have blown a ground on your amp but doubtful
really stupid question is it possiable one of the speaker wires is pinched or shorting out causing the static... i speak from personal experience on this
