Stereo Upgrade Advice Needed
I am interested in upgrading my stereo system but don't want anything too fancy or expensive. Weight is also a concern as I intend to take the car to HPDE and other track events.
I listen primarily to rock and popular music.
I already bought an Alpine 9857 HU so I can play my Itunes.
How would you recommend I proceed?
Thanks for your help.
And my second suggestion is for you to tell us how you like the music to sound. IE, flat and raspy, bright and thin, dark and muddy...
It terms of sounds, I would like the music to be clear and crisp and to be able to hear (perhaps feel) the bass. A lot of the music I listen to has the undertones of heavy metal, although I would not necessarily classify the music that way.
Keep the questions and advice coming!!
thanks
Sub box subthump, corvettecaraudio, NVTHIS etc
I would go with a 4 channel amp which would allow you to power some components up in the front door and then a sub in the back. Unhook or completely remove the rear speakers IMO you dont need them at all.
For components up front my favorites are http://www.edesignaudio.com/edv2/pro...products_id=49 or CDT CL-61s or Polk Momo. Either one you will be happy.
For sub I would deff do a single 12. Check out the 13kv http://www.edesignaudio.com/edv2/pro...products_id=31 Polk Momo 12, Kicker CVR 12, and others.
Amp you have options here and it also depends where you want to mount it, back wall, behind seat, etc. Killer deal on an amp right now is kicker kx650.4 last years model so they are cheap http://cgi.ebay.com/KICKER-KX650-4-Z...QQcmdZViewItem i just put this amp in a friends car a week ago its killer. That would power speakers and a sub. Other nice amps, Infinity 7541a, Polk Momo C400.4, eclipse, etc.
Let me know and i can answer any other ?'s
thanks
If you have anymore ideas I am open to them.
Couple of people mentioned sub-boxes and I will look into all of them.
Since I am concerned with weight I was wondering what people's thoughts are on the new JL subs that are out or soon to be out. From looking at the specs they appear to be pretty light weight. Don't know about the sound though.
since dynamat isn't exactly light by any standards, i would use a couple slabs of sound absorbing foam in the area right behind the seats and the cargo area (weight of this isn't more than 5 pounds for the foam)
As for a new head unit, this is highly subjective based on the options you want and how much fine tuning you like to do.
Knukoncepts has excellent wiring material. just makes sure you measure out how much you will need by plotting your wire route using thread or string.
my xtant was among my favorite amps only to be outshined by my current amps..but my current amps color the sound a bit here the xtant and soundstream will give you more accurate sound reproduction.
for a sub i was very happy with my id12v3 by image dynamics, it paired well with that xtant amp and pounded nicely. I recently swapped it out for a tc-sounds tc-9 which is supposed to be an amazing sq sub. I haven't been able to hear one yet but I took the dive and purchased one to see how it sounds. both of those subs are very reasonably priced.
for speakers, i had the cdt cl-61's and was pleased with them, but If i were you i'd go audition a few to see what speaker characteristics you like (warm, accurate, etc...)
definately put 2 layers sound deadinging and one layer of ensolite or similar in the doors. if you're that concerned about the weight it'd add...then go on a diet and call it even
that'll give you some great midbass/bass and round out the system very nicely.
