Sponsored by: Innova
How do I do this?
Old Mar 7, 2007 | 09:52 PM
Kale's Avatar
Kale
Default How do I do this?
Tweeter mount done by RockstarDesigns.
I sent them an email for a quote.
How does one go about making such a modification? I want to put my TN51s in the pillars, and that is the ONLY location where they don't scream like a baen sidhe.
Old Mar 7, 2007 | 10:10 PM
scott_fx's Avatar
scott_fx
build it like you'd build a sub box. mdf [square] ring mounted solidly then lay fleece over it and fiberglass it.
for the grill, you can cut a piece of plastic or mdf to fit inside the other ring then cover it with grill cloth
Old Mar 7, 2007 | 10:11 PM
Kale's Avatar
Kale
You make it sound so easy
So its not a bondo job?
Old Mar 7, 2007 | 11:05 PM
scott_fx's Avatar
scott_fx
nope, bondo will crack if put on too thickly. you can use it to fill in some gaps and what not, but don't go wild with it. it wont be really hard, just a lot of sanding and tweaking.
everything is easy to me (in my head)
Old Mar 7, 2007 | 11:09 PM
Kale's Avatar
Kale
What about the vinyl covering?
Old Mar 7, 2007 | 11:29 PM
wiz1500's Avatar
wiz1500
http://forums.corvetteforum.com/show....php?t=1373431
been there done that.....Mounting the tweet I used a plastic jar lid and cut the center out put a hole in the right spot on the piler. CA glued it all togeather then smoothed it all up with bondo.......The vinal is a *&%$# You may want to have a pro do the covers....
Scott is right though you cant make the bondo to thin....Insted of going with the glass I found plastic...remember if your wraping it you dont have to spend a lot of time with a perfect finish
Old Mar 7, 2007 | 11:42 PM
Kale's Avatar
Kale
Wow, that looks great!
Though im not completely clear on how you did it
I want mine to give me several tweeter options... so be completely hidden (and guard from uv)
Old Mar 8, 2007 | 10:26 AM
Kale's Avatar
Kale
Wiz, did yo ureuse the factory covers?
Old Mar 8, 2007 | 10:40 AM
wiz1500's Avatar
wiz1500
No
You will have to recover them ...The covers you pull off will be destrode
To How do I do this?
