Sponsored by: Innova
Speaker Baffles
Old Mar 8, 2007 | 12:20 AM
bomax's Avatar
bomax
Default Speaker Baffles
Good idea or ripoff?
Old Mar 8, 2007 | 12:29 AM
Kale's Avatar
Kale
Can you be more specific, please? Do you mean paying for premade vs making your own?
If so... Im not a fan of thin baffles. I like 1/2" or better thickness.
MDF has some damping properties...
I probably wouldn't get one thats a differnt material.
If you have a router, then make your own.
Old Mar 8, 2007 | 01:09 AM
bomax's Avatar
bomax
Sorry, I was referring to ones like these: http://www.crutchfield.com/S-SdhbWTz...roup.asp?g=762
Old Mar 8, 2007 | 01:17 AM
Kale's Avatar
Kale
OH the old XTC foam bits.
I had a set of those years ago.
They'll completely destroy your midbass and make your speakers sound very strange.
I would skip them.
Old Mar 8, 2007 | 01:19 AM
bomax's Avatar
bomax
Old Mar 8, 2007 | 01:39 PM
scott_fx's Avatar
scott_fx
if you're concerned about moisture you can use those just cut out the bottom portion and it should get you your midbass back. youcould also do the same thing with the disposable tupperware containers though.
Old Mar 8, 2007 | 04:45 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
the foam ones are crap because the foam isn't riged enough to replicate a good speaker box. I built a set of baffles from 3 .75" speaker rings and a 1/4" plate. The front bass is much tighter.
To Speaker Baffles
