Sponsored by: Innova
Bose malfunction question
Old Mar 14, 2007 | 12:25 AM
cclevel's Avatar
cclevel
Default Bose malfunction question
Have a 92 coupe equipped with the bose system. All goes well until occasionally the right rear speaker will sound like an explosion has occured in it, then buzzing very loud sounds and it will increase with engine speed added. Before long it will go away and be normal for awhile, then repeat. any ideas as to the problem ?. Thanks.
Old Mar 14, 2007 | 12:58 AM
bogus's Avatar
bogus
it sounds to me like the amp has died.
there is a capacitor on the amp that more than likely is the cause. they explode and then spread goo everywhere that eats things...
Old Mar 14, 2007 | 01:41 AM
hippy's Avatar
hippy
So what explains that after it dies and comes back to life? Does the goo go back into the capacitor and reincarnate itself until the next explosion?
Old Mar 14, 2007 | 02:55 AM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
Old Mar 14, 2007 | 07:08 AM
Aquaman92's Avatar
Aquaman92
Mine were doing a similar thing it was the amps I had them rebuilt a year ago that fixed the problem.
Old Mar 14, 2007 | 07:58 AM
-=Jeff=-'s Avatar
-=Jeff=-
The Amp is dying, the Capacitor may not have exploded, but might be leaking, so in some instances it still 'works'
there are a bunch of caps on each amp, I have replaced them on 3 sets and nobody I replaced them for has had issues.
Old Mar 14, 2007 | 10:39 AM
VenkmanP's Avatar
VenkmanP
Swap amps between the rear speakers. If the problem follows the amp then you know what to fix.
Old Mar 15, 2007 | 10:25 PM
BadjerJim's Avatar
BadjerJim
Yeah, it's a problem with the capacitors on the amp boards. Best info I have (from Dr. Don's Audio Repair) is that the C4 Bose amps were actually manufactured by Sanyo. And we all know what a top-quality brand Sanyo was in the mid-80's to mid-90's. NOT.
Realize that a capacitor "leaking" is an electrical term, not a physical term. The "leakage" refers to a gradually increasing electrical short within the capacitor, which inhibits its ability to store a charge and act like... well, a capacitor!
It has nothing to do with exploding or leaking goo onto the circuit board.
The point of this post is that if you remove the amp and examine it... the amp may look just fine. Yet still may have capacitors that are "leaking" in the electrical sense.
Old Jun 5, 2007 | 06:03 PM
kad92's Avatar
kad92
2nd Gear
Default the bose buzz
my 92 driver front speaker is buzzing loudly and ocassionally various other electronic sounds, what is the best way to remove the speaker????
Old Jun 5, 2007 | 08:08 PM
VenkmanP's Avatar
VenkmanP
I'm a EE, and 99.999% of the time when I say "leaking capacitor" I am referring to the electrolyte leaking out, aka "goo on the circuit board."
100% of the time when referring to C4 Bose amps, since that is one of their most common failure modes.
To Bose malfunction question
