Sponsored by: Innova
Installed a head unit, issues.
Old Mar 14, 2007 | 09:36 PM
FrostyZ28's Avatar
FrostyZ28
Default Installed a head unit, issues.
Someone help me please. I installed a Pioneer head unit today and I'm getting some feedback with the motor on and at idle. It's give off the sound of a bad ground. I'm no dummy, I've done installs a million times so I checked and rechecked all of the wiring, connections etc and can't come up with anything. Hell I even added another ground thinking that would solve the problem. Nope. Now, the head unit IS used..however it's only a few months old and I know the person I got it from so I can pretty much rule that out. I used the wiring harness from Peripheral that hooks the cd player harness to the factory one. I also got the SVEN7 but realize..well I don't have a BOSE amp, lol.
Anyway, it didn't make any noises with the factory stuff. Can anyone post up some tips? Maybe I overlooked something.
Thanks!
Also, it only seems to make the feedback noise at idle, it kinda goes away a bit when I get on the gas over 1500 rpms
Old Mar 14, 2007 | 10:22 PM
scott_fx's Avatar
scott_fx
do you have an aftermarket amp? if so it probably is a floating ground problem. try to ground the outside of the rca connection (the shield/ground, not the tip) to the head unit's ground
Old Mar 14, 2007 | 10:27 PM
DPG's Avatar
DPG
St. Jude Donor '06
seems like a common problem with these pioneers lately
Old Mar 15, 2007 | 06:25 AM
FrostyZ28's Avatar
FrostyZ28
No, only added the Pioneer head unit.
Old Mar 15, 2007 | 09:46 AM
DPG's Avatar
DPG
St. Jude Donor '06
did you ground it using the harness, or did you run your own ground?
Old Mar 15, 2007 | 10:03 AM
FrostyZ28's Avatar
FrostyZ28
Both
Old Mar 15, 2007 | 10:06 AM
Kale's Avatar
Kale
Originally Posted by FrostyZ28
Both
At the same time?
Fwiw, I tried moving the ground from the factory harness, to the chassis. The noise in the HU was actually a little worse. So mho, the harness ground is perfectly fine.
Old Mar 15, 2007 | 11:10 PM
FrostyZ28's Avatar
FrostyZ28
Originally Posted by Kale
At the same time?
Tried it just with the harness...then added another one and nothing changed
Old Mar 15, 2007 | 11:43 PM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
it may be an internal issue to the head unit itself with something not grounded right. do you know anyone else with another HU you could try?
Old Mar 17, 2007 | 11:30 PM
Tomulrich's Avatar
Tomulrich
I had the samd with the ground issue...everyone telling me I had a ground problem...went around and around with this. Go get a ground loop isolator from your local stereo store...put on on each RCA. I am convinced there is something in the Radio dash area that interferes with the aftermarket radios....mine was alos a pioneer. No noise after installing the ground loop isolators..
Tom
Old Mar 17, 2007 | 11:34 PM
FrostyZ28's Avatar
FrostyZ28
Tom
Would that apply to me since I'm not using the RCA's?
To Installed a head unit, issues.
