Sponsored by: Innova
In-Car Video: Audio Interference
Old Mar 27, 2007 | 09:52 AM
DPG's Avatar
DPG
St. Jude Donor '06
is there another camera you can borrow from a friend that is a different brand and try that one out?
jvp's Avatar
jvp
"Ask Tadge" Producer
Originally Posted by robvuk
Try plugging the mic adaptor into the camera without the mic and set the camera for external mic and see what you get.
Unfortunately, you don't get the choice between internal and external. As soon as the camera senses input on the mic jack, it disables the internal mic. I strongly suspect that JUST connecting the adapter won't be enough to trip the switch in the camera, and it'll still record from the internal.
jas
Old Mar 27, 2007 | 10:05 AM
robvuk's Avatar
robvuk
jas
The jack itself usually determines whether you have an external mic plugged in or not. It doesn't require a signal. The presence of a plug in the jack will make the camera record from whatever is in the jack. The adaptor alone will give total silence.
Old Mar 27, 2007 | 09:45 PM
jvp's Avatar
jvp
Click Here
Mic test.
1. No mic connected, car not running.
2. Fire car up, rev engine.
3. Connect mic adapter, no mic (no sound, as robvuk expected).
4. Connect mic. Rev engine.
5. Drop mic into center console. Rev engine.
Not sure where to go from here.
jas
Old Mar 27, 2007 | 11:21 PM
Rob Willis's Avatar
Rob Willis
...another thread that might be of interest.....
http://forums.corvetteforum.com/show....php?t=1624170
Old Mar 28, 2007 | 11:03 AM
robvuk's Avatar
robvuk
Click Here
Mic test.
jas
I noticed that this time, the recordings were very quiet and clean until you actually revved the motor. Did you by any chance rev it when you had the adaptor-no-mic plugged in? The purpose of this was to see if the camera itself created the noise but I see that the engine has to be higher than idle in order for the noise to be present. Even then it seemed that it was not that bad this time. I assume you were sitting still in your driveway. I can't help think that this still might be a vibrational problem with the camera. Did you try it outside but near the car? Have someone handhold the camera from a distance and then approach close to the car while you rev it. Then handhold while IN the passsenger seat.
I know this is a big PIA but it's the only way to narrow it down.
Old Mar 28, 2007 | 11:18 AM
jvp's Avatar
jvp
Yep. But obviously, there was nothing to hear. :-)
I was sitting in my garage, in the driver's seat, with the camera in my hand. Tried moving the mic around to see if it made a diff. What I didn't do was mount the camera back onto the harness bar while doing this test.
I should do that and repeat the tests. Perhaps lending credence to your vibration idea...
jas
Old Mar 28, 2007 | 11:49 AM
robvuk's Avatar
robvuk
jas
Yes, if you revved the motor and still didn't hear the noise that rules out the possibility that the camera itself (no mic) is NOT generating the noise.
Repeat this test again when you mount it to the harness bar. If it is vibration, it might make the noise even with no mic.
Now that you mention that you were handholding, it was definitely much better and hardly noticeable noise until you actually revved it.
Old Mar 29, 2007 | 08:36 AM
jvp's Avatar
jvp
I drove to the store and back with it mounted on the harness bar last night, but I forgot to unhook the microphone. I did have a large rubber (inch thick) "shim" between the camera and the harness bar, as a form of vibration damping. The noise is still horrendous.
I may need to EBay this camera.. :-(
jas
Old Mar 29, 2007 | 09:59 AM
robvuk's Avatar
robvuk
jas
Probably a good idea.
Old Mar 29, 2007 | 09:13 PM
jvp's Avatar
jvp
More info. I ran another set of tests this evening, with the camera sitting in my lap during a "spirited" drive. The first recording I took was with the external mic in place. Half way through the drive, I removed the external mic and relied on the internal mic. No difference in sound. Still that high-pitched, constant chirping and static noise, overwhelming the audio.
The second recording I took was with the microphone adapter in place, but no mic attached. I've included a link to this recording. At first, you'll hear nothing. But if you crank the volume up, you will here my door chime ring a couple of times. Then you'll hear me say something like "Camera still in lap, microphone adapter, no mic." But it sounds like I'm mumbling. Then faint engine noises.
So the camera is still picking up faint audio, even without a mic attached.
Half way through the recording I popped the mic adapter off and recorded a bit with the internal mic again.
Click Here
Other than trying another camera (which I don't have access to) I'm not really sure what to do at this point. :-(
jas
Old Mar 29, 2007 | 10:39 PM
robvuk's Avatar
robvuk
Click Here
jas
That's the darndest thing I've ever heard. It was clean until you started driving, which indicates that it is some kind of interference coming from the engine or vibration. The puzzling part is that it is there with either the internal OR the external mics. So it's not a problem with the mic but yet it was NOT there without any mic at all. The faint sound you were getting is probably from the switch in the connector is not completely separating the circuit. I've got to say though, it was not nearly as bad with the unit in your lap. I'm still thinking a vibrational problem here and if that's the case, the camera itself is at fault and would have to be serviced or replaced. Try the camera in your lap in another car preferably one that rides as rough as the Z.
Old Mar 30, 2007 | 04:57 AM
  #33
jvp's Avatar
jvp
Get this.. http://www.youtube.com/watch?v=uuNPpX2R1N4. Someone with the exact same issues with that camera, in-car. He solved it the hard way: a digital sound recorder and mixing the sound into the movies after the fact. The difference in sound quality is AMAZING.
jas
Old Mar 30, 2007 | 11:10 AM
  #34
robvuk's Avatar
robvuk
jas
Well there you go. It's apparent that the camera is inherently bad. I would prefer to buy a better camera before the expense of external recorders. But I'd still check and see what it does in another kind of car, like a luxury daily driver. Just for curiosity now.
Old Mar 30, 2007 | 01:25 PM
  #35
jvp's Avatar
jvp
Possibly. But I can't return this one, and decent ones are going to run me a whole lot more money. Plus, I like the fact that this one records directly to MP4 on SD cards. Makes transfering to the computer instantaneous.
As for further testing with it, I'm not going to bother. I think it's pretty obvious this thing is a piece of junk. :-(
jas
Old Mar 30, 2007 | 05:18 PM
  #36
DPG's Avatar
DPG
St. Jude Donor '06
you can cut the sound form yours pretty easily and add a soundtrack. A lot of computers come with that capability these days. macs have it built in.
Old Mar 30, 2007 | 07:27 PM
  #37
robvuk's Avatar
robvuk
I agree, but still easier said than done. I download full resolution DV to my Mac just as easily as any memory card with compressed MP4 and gives me amazing abilities for editing all included. But changing the sound track requires skilled editing to make it look and sound right. Gear shifts, full throttle, partial throttle and tire noise all add up to a synchronous nightmare. You might be better with a set of samples and a keyboard for replacing track audio. hmmm.... I hadn't thought of that before. I just might give that a try. Good audio on a video makes a world of difference.
To In-Car Video: Audio Interference
Old Mar 30, 2007 | 09:46 PM
  #38
jvp's Avatar
jvp
The main problem is a volume issue. The camera has an "external microphone volume" setting. I set it all the way down to "1" and recorded some high-rev driving.
You'll have to turn the volume up on your computer. You'll notice the "chirps" are still present, but not as bad. And the "clipping" is also present, but not as bad.
My external mic doesn't have its own volume setting. It's either "on" or "off." A different microphone with its own volume setting may help. But I'm still not sure by how much. It's very clear that the audio recording circuitry in this camera is junk.
Click Here
jas
Old Mar 31, 2007 | 12:29 AM
  #39
robvuk's Avatar
robvuk
Click Here
jas
Mics don't normally have volume controls. You would be hard pressed to find such an animal. Yes the noise is still present, just at a lower volume. The real problem is that it makes that noise even with the internal mic. Most cameras DO have what they call AGC, automatic gain control. The AGC circuit COULD be overloaded with an abnormally high output mic, but again, it does it with the built-in mic too. I think it's just poor audio electronics. Now that I think about it, it very well could be a problem with the AGC circuit itself. Applying too much gain and clipping the input from sound levels that are anything over a whisper. Normal speaking voices and background sounds seem to work fine. SOME of these AGC circuits actually have attenuators to adjust how much gain control it has. The problem here is that taking one of those miniature devices apart to see or get at it, requires a real little guy with slanted eyes.
Old Apr 1, 2007 | 11:25 AM
  #40
jvp's Avatar
jvp
I have an older (late 90s vintage) Sony Hi8 camera that has a firewire port on it. Copying videos from it to my Mac takes quite a bit longer than just moving an MP4 file over. But, I mounted the camera up and took a drive.
Click here
Very clear, very precise audio (and very loud road noise, as expected). But, the engine revs are crystal clear. About 3 minutes into the ride, the camera stopped recording on me, for some reason. So I need to figure that one out. But, aside from that, I may have my solution.
jas
