Sponsored by: Innova
Ipod2car issues
Old Mar 31, 2007 | 11:21 PM
Willsyb's Avatar
Willsyb
Default Ipod2car issues
I recently installed the ipod2car interface in my C5. Unhooked my disc changer, and simpy plugged in the ipod2car, very easy installation.
Problem is, I'm now getting a whining sound through my speakers as well as a chirping sound at steady 1 second intervals. This happens both when the Ipod player is hooked up, and when its not. Thought at first my amp was going bad, but when I disconnected the ipod2car, and reconnected the factory changer, all the problems went away. The issue is clearly with the ipod2car.
Any of you guys ever run across this? Think I have a bad interface?
Old Apr 1, 2007 | 02:41 PM
jcgunn's Avatar
jcgunn
I tried the iPod2car in my 03 vert. It worked intermittant at best. Tried another iPod, same thing. Got ERR messages or could not change songs or the iPod would run and no sound went thru the unit. Gave it up as a bad idea...
Good luck
Gunner
Old Apr 1, 2007 | 02:54 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
yes, I had the same two issues as the last 2 posts. Now I have the Auxbox. No pop, whine, nothing. I just loose the ability to change the iPod from the radio. I think this is why I see hundreds on ebay going for 25 bucks.
Old Apr 1, 2007 | 07:45 PM
Willsyb's Avatar
Willsyb
May have to investigate going that direction. Is your Auxbox from the same maker as the ipod2car (perephrial)?
Old Apr 2, 2007 | 09:45 AM
screw991le's Avatar
screw991le
It is a PAC AUXbox
Old Apr 3, 2007 | 04:56 PM
BanditSRT's Avatar
BanditSRT
I currently have the same two "issues" as you. I wouldn't really call them problems though. I only get them when the volume is turned up relatively loud and the iPod isn't connected.
Old Apr 4, 2007 | 07:23 PM
jason815's Avatar
jason815
Default I have seen exellent results
I have seen and heard exellent results from the use of the
iPod2Car (PXHGM4C) I have heard not so good things about this auxbox though...
Old Apr 22, 2007 | 10:34 PM
Twisted99's Avatar
Twisted99
Don't have any of those issues with mine, but sometimes lose ability to change track from radio. This also happens in my Tacoma.
Old Apr 23, 2007 | 10:46 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
installed 1 of these today in my 98, direct connect to radio and so far no problems ( here's keeping my fingers crossed I guess )
Old Apr 24, 2007 | 01:55 PM
bilx013's Avatar
bilx013
St. Jude Donor '12
I have the Ipod2Car direct connent to radio and have no problems. maybe once in a great while I will have to press teh next button twice to have it change songs
Old Apr 29, 2007 | 09:26 PM
G8rDMD's Avatar
G8rDMD
National Champs Gators 4 St. Jude '09
St. Jude Donor '10-'11
I have the ipod2car as well with the weird chirping noise... It's not annoying enough to make me think it's a problem--the music drowns it out anyway
Old Apr 30, 2007 | 01:39 PM
Willsyb's Avatar
Willsyb
Agreed, I'm living with it. It's not that bad rolling down the road. It's just those soft, slow songs that you can still hear the other noises in the background.
I think eventually, I'll probably go with something different.
Old May 3, 2007 | 06:52 AM
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
I don't have any odd noises coming from my ipod2car.
I do however have a few issues with the functionality of it. For instance, sometimes when I am playing the ipod and turn off the car, when I start the car back up, sometimes it will resume playing of the ipod, and sometimes I have to hit the play button on the ipod face again to get it to start.
Then sometimes after the first song when first starting up the car, it will stop and I have to hit the play button on the ipod again.
The last is that I have times where I have to hit the "next" button 2 or more times to get it to go to the next song. most times it works ok, but sometimes it does this.
To Ipod2car issues
