Sponsored by: Innova
Dbl Din C5 Install Pics
Old Dec 27, 2007 | 03:22 PM
Fasthotrod's Avatar
Fasthotrod
Originally Posted by TheRadioFlyer
The nearest grounding point without punching a hole in your body to gain access to the frame ground is the seat mouting bolt. You can also use the inner door frame but the bolt there is much smaller.
Fixed your post.
The 'closest' ground to the rear of the car is the factory ground in the rear passenger wheel well. It's located at about the same level as the upper A-arm, towards the rear of the car.
I placed my power distribution in the rear passenger storage bin and dropped a ground out of the bottom of the bin and connected it to the lug as pictured above.
Hope this helps.
Mark
Old Dec 27, 2007 | 08:00 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
Originally Posted by mickey_7106
wow great job on the install . just one quick question. did you move the A/C controls down a bit or is still sitting on its stock location?
they got moved down
Old Mar 14, 2008 | 01:33 AM
av8rdavid's Avatar
av8rdavid
Yep, the rear components need a ring as a spacer....The drivers side is TIGHT since you have the fuel fill elbow in the way.
Just the right size spacer with a little trial and error to get the proper mounting depth and still enough room for woofer excursion without hitting the grill...
If you grind your ring too much, then space it with a little dynamat to make a nice seating of the woofer.
Old Jul 23, 2008 | 11:02 AM
whompa1's Avatar
whompa1
This is where Dennis mounted the sirius antenna before he brought the car to me but we learned it has to be horizontal for good reception, the nav antenna is also back here
Where exactly is this on the car? I am currently trying to install a double din Kenwood and I am not sure where to put the GPS antenna. Thanks.
Old Jul 23, 2008 | 12:24 PM
nextime's Avatar
nextime
The GPS antenna can be mounted under the wiper arms area. GPS can go through plastic but not metal.
I install small Antennas in GPS Tracking systems like the SAT ones used in the picture above. They also work very well under fiberglass too.
Old Jul 23, 2008 | 12:48 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
thats a piece of plastic he mounted it too, imo under hood by battery is easier of if you have a vert, open the trunk and mount the antenna in the opening behind the trunk lid and vert lid it will fit right in there and wont interefere with opening and closing at all
Old Jul 23, 2008 | 01:02 PM
ZexZo6's Avatar
ZexZo6
Great thread
Old Jul 23, 2008 | 01:37 PM
pentavolvo's Avatar
pentavolvo
i remeber doing this car like it was yesterday lol
Old Nov 20, 2008 | 07:31 PM
Slow Z06's Avatar
Slow Z06
I need more pics of the actual install. just started mine tonight and need to know how to mount the radio itself
Old Nov 20, 2008 | 11:49 PM
pentavolvo's Avatar
pentavolvo
this is straight old if u look at the date... get some metal and fab brackets up is the best way
ace hardware is where it is at
Old Nov 21, 2008 | 09:10 PM
0Double D Mods
Former Vendor
Wait till spring Greg and 2 years later you will be doing an upgrade
Old Nov 21, 2008 | 09:15 PM
pentavolvo's Avatar
pentavolvo
pm me with details im looking forward to it... we both learned alot about the dbl din mod that day, like what pieces specifically not to even attempt to remote lol
Old Nov 21, 2008 | 11:28 PM
  #33
perfectlyfrank's Avatar
perfectlyfrank
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Cruise-In 8, 9 & 11 Veteran
First off Dennis has a beautiful car and had a killer list of equipment to put in this baby.
First off anyone who claims dbl din mod is easy is seriously out of there mind I wont go into details but my god PIA, Ill think twice before quoting a customer for install with that haha. Dennis modded the bezel himself and brough that to me, but that still left lots to do behind the dash to make everything fit. Ok here we go with pictures.
Shouldn't the part about the double din mod be "second off"?
Old Aug 13, 2011 | 08:32 PM
  #34
-Fidanza-'s Avatar
-Fidanza-
Did you have any problems sinking the radio back into the dash? I just got the Pioneer AVH 3200 and it hits the metal on the top and I believe the plastic in the back of the head unit. The a/c duct is right behind the radio right?
Old Aug 14, 2011 | 12:08 AM
  #35
pentavolvo's Avatar
pentavolvo
vintage revival from the dead... i have installed numerous dbl dins never had an issue with hitting the plastic from vent
Old Aug 14, 2011 | 10:47 AM
  #36
0Double D Mods
Former Vendor
wow long time ago
and to think this install started it all.....
Old Aug 14, 2011 | 03:46 PM
  #37
nickwfd92's Avatar
nickwfd92
Greg,
Looks great like always, how was the install of the amp on the rear? I am planning on moving my one amp there was it easy to just put a piece of MDF behind the carpet and then screw into.
Also what gauge wire did you go with. I have 4 going to a disblock and then 8 going to the amps. I am thinking of going to 1ga to a disblock to 4 gauge to the amps.(would you use the copper/all or use 99.9 OFC wire.
Amps Image I4500 bridged and then a PDX 1000.1.
Thanks Nick
Old Aug 14, 2011 | 10:41 PM
  #38
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Very nice job!
Old Sep 20, 2011 | 10:31 AM
  #39
sts57c5's Avatar
sts57c5
Wish I could find someone in the huntsville area to perform this mod to my c5 wow very impressive .
