Sponsored by: Innova
where is your amp?
Old Apr 28, 2007 | 05:37 PM
Tikiman12's Avatar
Tikiman12
Default where is your amp?
So i'm trying to figure out the best location for my amp to my sub box in the rear. Also i'd like ot know how you mounted it.
i'm considering either behind the seat or ON the rear flat against the rear deck. BUT i dont know how yall have those mounted in these locations.
Pictures with info would be appriciated {bad imaginiation}
Old Apr 28, 2007 | 09:55 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Behind my seats
Old Apr 28, 2007 | 11:13 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
back wall
Old Apr 28, 2007 | 11:19 PM
TortureTest's Avatar
TortureTest
Underneath my HUGE sub box with 6x9's attached to the sides....I think it overheats and I have no friggen space....gotsa do something about it !
Old Apr 28, 2007 | 11:21 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
In a box
and on the rear wall:
Old Apr 28, 2007 | 11:54 PM
fej's Avatar
fej
Underneath a non-power z06 passenger seat. However I am not that cool to post a link so check my corvette photos.
I personally like the back wall for the coupe for amps. Racks are always nice as well. Pick an amp under 15"x9"x2.25" and you can fit under the non power seat (carefully .. mine is only 1.5" high and 17" long and BARELY fits).
All depends on your goal for the system, how stealth you want it to be, your skill set, or your comfort with the al'mighty $$$.
Fej
Old Apr 29, 2007 | 12:39 AM
Tikiman12's Avatar
Tikiman12
what is it mounted to? the ones on the back wall and behind the seat, how do you ahve it stationary?
Old Apr 29, 2007 | 12:50 AM
Kale's Avatar
Kale
liquid nails a board up, then screw it through the carpet. Your gas tank is behind it, so dont pierce through the board!
Old Apr 29, 2007 | 09:14 AM
screw991le's Avatar
screw991le
I siliconed an MDF board to the body, just in case I wanted to take it off later. Liquid nails may never come off. IMHO.
Then just bolt the amp down to the siliconed MDF.
Old Apr 29, 2007 | 10:10 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I went ahead and drilled mounting holes for 4 bolts on the corners. the holes are so small that the untrained eye will never find them. I ONLY did this to the rear wall because access behind the panel was easily done through the taillight holes.
Old Apr 29, 2007 | 12:11 PM
kirk78h's Avatar
kirk78h
OK, I glued a piece of 1/2" MDF to my back wall, and am ready to mount my amp. I had planned on running the ground to the passenger seat bolt like so many have posted. However, I unpacked my amp kit from knukonceptz, and the ground wire is only three feet long. After a little research, I read that grounds should be kept as short as possible. So, for amps mounted on the back wall, is there another convenient (within three feet) ground location?
Thanks,
Kirk
Old Apr 29, 2007 | 12:14 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
I ran my ground wire thru the back wall and into the rear end clip's cavity where the tail light wires are.
I then bolted the ground wire to the frame and covered it in sealant.
RainJ's Avatar
RainJ
Old Apr 29, 2007 | 12:15 PM
RainJ's Avatar
RainJ
and with the cover off:
Old Apr 29, 2007 | 01:00 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
On the ledge behind the seats!
Old setup:
New setup:
Old Apr 29, 2007 | 07:25 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
this would work.
Old Apr 29, 2007 | 10:37 PM
gator79's Avatar
gator79
Originally Posted by TheRadioFlyer
In a box
damn that thing should rock. is that video screens between the amps?
To where is your amp?
Old Apr 29, 2007 | 11:35 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
No vid screens. Those are my Xovers. I decided to keep them in a group for easy access and adjustment....not to mention they look cool. The only real downside is that i had to run longer speaker wires.
Old May 2, 2007 | 03:38 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
One behind the driver seat, one on am amp rack above the cargo doors. Passenger side has the satellite stuff behind the seat.
Old May 2, 2007 | 03:45 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
to the person who asked about keeping ground wire to 3 feet or whatever ive put amps on back wall and ran to seat bolt no problem at all
