Sponsored by: Innova
System Pics!! Comment Please
Old Apr 29, 2007 | 10:29 PM
NorthTexasVette's Avatar
NorthTexasVette
Default System Pics!! Comment Please
Here are a couple pictures of my system. I absolutly love the way it looks, but I am wondering if it will sound better if I install a 5/8 inch piece of wood about 1 1/2 inch away from the subs. That way the bass can bounce off of the wood causing a better sounding bass. What do you think?
Old Apr 29, 2007 | 10:36 PM
Kale's Avatar
Kale
Looks good. If you put a board that close to your subs, you might end up with some problems. In what way do they sound bad? I find crossing subs over just a 'bit lower' helps.
Old Apr 29, 2007 | 10:51 PM
NorthTexasVette
Well, Ive had a dodge truck and a ss camaro forever and in each one i had a system. In the camaro the subs were about 3 inches from hatchback and the subs sounded so great bouncing off that glass. in my truck i had a box that was custom made to fit right behind my seat and it had a piece of wood going ove rthe sub.. heres a crappy pic of the sub i had in my truck that sounded awsome. kinda the same idea i had for the box in my vette with the 4 tens..
Old Apr 30, 2007 | 12:03 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
definatly looks awesome. My only concern would be a lack of Airspace. what you might want to consider is wiring the inner two subs out of phase. This would cause the inside subs to fire inversly with the outer subs in theory giving you a more powerful sound.
Old Apr 30, 2007 | 12:06 AM
Kale's Avatar
Kale
Generally the farther away from you, the better a sub sounds. This is one of the reasons hatchback installs with rear facing subs are so good.
Are your subs too loud? too quiet? too sloppy? dont play low enough?
Old Apr 30, 2007 | 12:12 AM
NorthTexasVette
when I turn up the volume the subs sound like they are almost blown.. you know that sound that it just feels like you need to turn it down. the subs and the amps are brand new and just can't get the sound im looking for.
Old Apr 30, 2007 | 12:13 AM
NorthTexasVette
i'm not sure i know exactly what you mean.. do you have a website with a diagram or something.. I would love to try it.
Old Apr 30, 2007 | 12:22 AM
Kale's Avatar
Kale
How much power are you giving them, and what are they rated for RMS?
Sounds to me like they are either under powered, or you are just trying to drive them too hard.
You dont have any bass boost on do you?
Old Apr 30, 2007 | 12:39 AM
NorthTexasVette
Well, i know they are the d3 amps. I am not sure what model exactly though. I was wondering since I have two amps I should be able to test to see if it is underpowered. My subbox is in two chambers. 2 10s in each chamber. If i hook up one amp to just one of the subs and the other amp to the other sub I should see what the difference is with the more power. Here is a pic of how the speaker wire is hooked up to the amp right now.. this is how they did it when i got it installed..
Old Apr 30, 2007 | 12:44 AM
Kale's Avatar
Kale
Is that wired to the negative of 1 &2 and negative of 3 & 4 ??
Old Apr 30, 2007 | 12:52 AM
NorthTexasVette
Theres just those two wires going to the amp. it goes ( ) (x) ( ) (x) x is for where the speaker wire is connected.. I'm not sure which is negative or posative.. the other amp is wired up different. it goes
( ) (x) (x) ( ) ... whats going on here.. was it suposed to be wired this way?
Old Apr 30, 2007 | 01:06 AM
Kale's Avatar
Kale
Typically, it would be wired like this when bridging:
(x) ( ) ( ) (X)
So you have the positive from channel 1, and the negative from channel 2.
That makes it one big circuit, so you get the power out of both channels.
Old Apr 30, 2007 | 01:10 AM
NorthTexasVette
(x) ( ) ( ) (X)
So, I will change that wiring tomarow. Am I going to need to take the box out and check the wiring inside the box? Or, if i just change the wiring like you said I should be fine and hopefully get a better sound?
Old Apr 30, 2007 | 01:13 AM
Kale's Avatar
Kale
Honestly, I wouldn't suggest changing anything around before you check the owners manual for what it says on bridging, and checking the wiring on the subs.
To make sure you dont run in to any problems.
Old Apr 30, 2007 | 01:15 AM
NorthTexasVette
Will check it all out first thing tomarow. Gotta find manual now.. lol.. Will post update tomarow!! THANK YOU
Old Apr 30, 2007 | 01:16 AM
Kale's Avatar
Kale
looks like 400 @ 1 or 200 @ 2
What impedence are your subs?
Old Apr 30, 2007 | 01:17 AM
NorthTexasVette
Umm.. I know this sounds dumb, but what does impendence mean?
To System Pics!! Comment Please
Old Apr 30, 2007 | 01:18 AM
Kale's Avatar
Kale
They should be something like
"svc 8 ohm"
or "dvc 2 ohm" or "Dvc 4 ohm"
Old Apr 30, 2007 | 01:20 AM
NorthTexasVette
oh okay.. I believe they are 4 ohm.. But i would have to double check about that..
Old Apr 30, 2007 | 01:26 AM
Kale's Avatar
Kale
Cool, post up when you find out, and we can help you with the wiring.
