Sponsored by: Innova
Ready to pull the trigger! Please Help!
Old May 30, 2007 | 07:57 PM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
Thank you, both, so much for the information.
Komoman - It seems perfectly logical. If you bridge you send 300 watts to a combination of the voice coils (150 per), so if I run them like two seperate speakers I still get 150 per voice coil. I never thought of that.
Thanks again!
Old May 31, 2007 | 04:15 AM
Mister Peebody
From the JL Audio website:
What happens when you run different signals into each voice coil of a dual voice coil speaker?
...If a dual voice coil subwoofer must be wired to two independent channels, the inputs to both channels should ideally be the same (summed mono) and every effort should be made to match the gains of both channels as closely as possible.
Does this mean that I should Y the left and right down to one, then Y the one back to two?
