Sponsored by: Innova
Audio question for C-5 Bose
Old May 30, 2007 | 10:19 AM
Phanni's Avatar
Phanni
Default Audio question for C-5 Bose
The previous owner of my 2000 vert installed a Sony head unit. It Looks like crud {IMHO} because it is silver in a black dash. I have a complete Bose system that I'd like to use {return to stock}. I found the installer of the Sony Unit had cut off the Bose head unit connectors and spliced in all the unit power, power attenae , wires etc .
He also installed an amp in the trunk area which I'm pretty sure can be removed easily. The unsused wires to the speakers {at the speaker end} are still there along with the ones from the amp.
What would everyone suggest as to how to get the connectors for the original unit back into the car? Can I buy just the connectors from GM or do I have to buy the entire radio cable harness?
Please don't give me a lot of flack about "downgrading" to the stcok radio, I've made up my mind what I want and it isn't a rolling boombox.
I hope someone can be of help with some suggestions.
Old May 30, 2007 | 10:33 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
You're right about the flack/flames coming for going back but if thats what you want to do...
I think you'll find it nearly impossible to get a new harness since the cabling goes everywhere under there. You can try getting an OEM harness or I'd suggest going to a junkyard and cutting out the piece you need. With some work and a good soldering iron you could match the color coded wires back together.
If you are really set on the Bose I think that's your best option but for the trouble I think I'd look over some other Sony H/U's tos ee if you found one you could live with AND has the same back connector.
Other questions,,, are you sure the PO didn't also change the speakers? Seems like he would have with that H/U and an amp. If he did you're going to need more than a Bose H/U to get back to original. And who knows what else he cut while in there.
Good luck.
Old May 30, 2007 | 10:38 AM
Phanni's Avatar
Phanni
I have a complete set of Bose speakers W/amps, a couple of head units, and a remote CD palyer in my possesion. The rear speakers have been change, I haven't looked at the fronts.
I plan on installing the Sony into my Pickup.
H*ll I'm old and Frank Sinatra isn't improved by a 1000 W/ amp
Old May 30, 2007 | 12:06 PM
Vette-kid's Avatar
Vette-kid
Old May 30, 2007 | 02:18 PM
Fasthotrod's Avatar
Fasthotrod
Man... it just pisses me off when somebody chops up the stock wiring harness when a simple plug in module is all that is needed. Lazy bastages!
Send me the name of the previous owner so I can pop him in the head with the back of my hand!
I agree with jbondfl. Try and get a connector from another car and just crimp/solder the plugs back in.
I think the factory service manual lists the name of the company that makes the connectors... you might be able to get a replacement plug and just re-install it on the stock wiring... but you would be losing some length overall, depending on how short it was cut back.
If you need a wiring harness, get up with Gene at Genes' Kar Shop. (Supporting vendor) I have gotten parts from him, and he is always excellent to deal with.
http://www.geneskarshop.com/
Mark
Old May 30, 2007 | 02:32 PM
Phanni's Avatar
Phanni
Thanks dude, I gopnna go over to the parts counter at the dealer this afternoon and see if the connectors are available.
To Audio question for C-5 Bose
