Sponsored by: Innova
Setup thoughts
Old Jun 14, 2007 | 04:08 AM
jarda's Avatar
jarda
Default Setup thoughts
Thinking of using
Kenwood DNX7100
focal 165V3E
focal sub 33v2
focal amps fp 1800
fp 475
Still new to this and learning have been looking Jl's amps and sub 13w6... (might lean toward jl sub) Thought I'd put this out there to see what people were thinking.
Jarad
Old Jun 14, 2007 | 08:10 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
I'm a big fan of Focal so I can't argue with your choices there!
I don't know the Kenwood, but a number of folks that post here have installed it and are very pleased. Garmin's NAV software is the best I've used, hands-down so from that standpoint it's hard to go wrong with that choice.
The sub choice is the real question here. The Focal is going to be a fast, tight and musical sub. The JL is a ground-pounder. While in the right box with the right power I'm sure it could also be very musical the W6/W7 design is power hungry and designed for output. The Focal has a sensitivity of 90db where the W6 is 87.4 so you'd need nearly double the power to produce the same decibels given the proper "ideal" enclosures for those subs. Folks normally dump HUGE amounts of power in the W6/W7 subs so the separate amp to drive it is a good idea. As always, you need to choose based on what you listen to and how you listen to it.
Old Jun 14, 2007 | 12:06 PM
DPG's Avatar
DPG
St. Jude Donor '06
garmin based
focal (from all that I hear) wish I could fork the dough for some
The sub is sometimes the hardest decision to make. Choose one on what type of music you listen to. if you let us know what you like, we can suggest a few subs to meet those requirements
Old Jun 14, 2007 | 01:19 PM
scott_fx's Avatar
scott_fx
i always ask this first; have you actually listened to focals? I wouldn't buy them before you have a chance to listen to some. focals are accurate/detailed but a little bright imho. You may not like that sound and may rather something warmer like dynaudio.
I agree completely (as usual) with komon,about the subs. A 12w7 will be a bear to work into your vette, a 10w7 slightly easier. Personally I opted to go with a tc-9 sub from tc sounds.
here is some ref to taht sub:
http://forums.corvetteforum.com/show...9&postcount=35
here is a related thread that may give you more info:
http://forums.corvetteforum.com/show...1719483&page=2
I have also known a few people that swear by the peerless xls for subs. Check those out as well
Old Jun 14, 2007 | 01:30 PM
scott_fx's Avatar
scott_fx
also, check out this review on the xls:
http://www.mfk-projects.com/titanic_mkiii_vs_xls.htm
and at under $200 it's a great choice
http://www.madisound.com/peerless.html
Old Jun 14, 2007 | 09:11 PM
jarda's Avatar
jarda
Would like to say a big thanks to everyone on this....This is pointing me in some good directions....will update if you want. Thanks again
Jarad
Old Jun 14, 2007 | 09:19 PM
scott_fx's Avatar
scott_fx
also...dont' spend too much time thinking about the subs. they only cover 2 octaves. i'd concentrate on your mids and highs more then bass
Old Jun 14, 2007 | 09:25 PM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Jarad
ABSOLUTELY! We're sick.. we love this stuff.
Always amazes me the focus on subs. I guess SPL's rule. If you really care about what your system SOUNDS like put your money and your time into your front sound stage.
Old Jun 14, 2007 | 11:48 PM
DPG's Avatar
DPG
St. Jude Donor '06
i guess I got lucky on my front stage. i was happy with it and thought my subs lacked a bit. im glad I didn't change them out before adding a bigger amp. I learned my lesson there to give each component the power it needs and then some you guys are right though, each piece needs thought to all work together
Old Jun 15, 2007 | 12:18 AM
jarda's Avatar
jarda
Why my dumbness is flowing freely What is the reasoning behind mounting sub with magnet down cone up or magnet up cone down
Jarad
Old Jun 15, 2007 | 01:36 AM
scott_fx's Avatar
scott_fx
no advantage unless your sub wont fit inside your box. it was more commonly used back in the 90's when subs need larger enclosures and you would to isobarically load a pair of subs (cones facing each other running out of phase). This would allow you to put a sub in an enclosure half the size that it required. the cost...well you're using two subs to get the same output as just one in a normal size box
Old Jun 20, 2007 | 01:47 PM
SeeSixGoFast's Avatar
SeeSixGoFast
I'm using a Kenwood DNX-7100 with Focals in the doors, JL's behind the seats and a JL Stealthbox with 10" subwoofer. I've also got an Alpine 4.100 amp in the passenger side cubbyhole. I couldn't be happier with the setup. I listened to every conceivable speaker and speaker combination before settling with the Focals. They simply sounded the best -- clearer, cleaner, not to bright. The matching tweeters are directional so you can experiment with them to get the best sound for your tastes. The subwoofer is key; I like the heavy thumping base the JL provides when I crank it up.
Old Jun 20, 2007 | 01:52 PM
SeeSixGoFast
To Setup thoughts
