C5 Bose Base problems, need HELP!
The Bose amplifiers are located in the doors, right inside the speaker pod. They have been known to fail, and it is very possible that it is case in your situation.
You might be able to have your amps repaired, but I'd bet it is easier to just replace them. A lot of guys pull the stock system for an aftermarket system, and have their old Bose speakers/amps on a shelf. (I know I still do... I'm too lazy to list them for sale.)
You see them listed every so often... but it might be easier to post a WTB (want to buy) thread. You can get a set for about $50-100, I'd guess.
I would upgrade to an aftermarket system... but that's just me. Hope this helps.
Mark
If you intend to keep the bose system, look on the C5 FS section. Also check ebay. you may do better just getting the entire front speaker section instead of just the amp.
Mark[/QUOTE
Thanks, someone said there was a fuse for the Base Amp, We'll see.
