Sponsored by: Innova
Kenwood DNX7100
Old Jun 27, 2007 | 09:06 AM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
There are three connections on the Kenwood, pretty fool proof...
1. USB - This is for any device, but on the iPod it communicates the track/song info and iPod control
2. Audio - standard pin plug (like headphones) - the ip200 / 300 have this audio pin to plug into that.
3. Video - the IP300 has this additional pin on it for 5gen iPod video
All that being said, I had mine plugged into the video by accident, but that took all of 30 seconds to figure out, he stated that he is getting video so I have to assume that he plugged in the audio into the correct port.
Yes, it is possible (since you tried two cables) that the Kenwoods ipod audio cable is bad.
This may or may not work, can you try a dual pinned headphone style cord from radio shack or something to test the audio from the headphone output of the ipod (or anything else), the only other alternative is to switch out the HU. Like others have said, I do not believe there is any configuration, I have been through most menus and have not seen this as an option.
Good luck on this...
Old Jun 27, 2007 | 07:57 PM
dynosmith's Avatar
dynosmith
Yes, you are correct - audio, video, and usb - they are all plugged in correctly. My issue is bigger than the iPod as I found out today, I have found that the DVD sound is not working either. Actually what I have discovered is that if I just connect a speaker directly to the RCA's or regular speaker wires on the HU, I get sound for everything - iPod, DVD, Tuner (louder than the rest), etc. But when I connect them to the wires on the GMCO, I only get sound on the tuner. What could be different about the sound from the Tuner vs. all other sources that it works through the car speakers and the rest do not? Is it something with the Bose system? Any suggestions?
Old Jun 27, 2007 | 08:46 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
your stock amp isnt turning on unless you are on tuner, basically u connected the power antenna wire instead of the amp turn on wire
so go behind the dash and find where you hooked the power antenna wire from the kenwood to the gmco and unhook that and use the amp turn on wire instead and you will be set
Old Jun 27, 2007 | 09:12 PM
dynosmith's Avatar
dynosmith
You are right on, just found that about 5 minutes ago with the help from friend. Should I use the RCA or normal wire outputs from the 7100?
Old Jun 27, 2007 | 09:23 PM
pentavolvo's Avatar
pentavolvo
uhhhhhhh, try the rca's if its not getting loud enough go to the speaker wires
if i recall on a bose car you deff use rca's and on the non-bose I dont remeber
Old Jun 27, 2007 | 09:40 PM
ttomczak's Avatar
ttomczak
St. Jude Donor '06
Great catch!!!
Old Jun 28, 2007 | 12:06 AM
dynosmith's Avatar
dynosmith
I have it all working now - thanks to both of you!! I will let you know how well the bluetooth is working after a day or two of using it...so far it seems really nice.
Old Jun 28, 2007 | 12:13 AM
Klaus-96's Avatar
Klaus-96
2019 Z06 2LZ A8 Coupe
FYI - Kenwood has discontinued the HD Radio tuner KTC-HR100TR.
Old Jun 28, 2007 | 02:42 PM
Nelson10's Avatar
Nelson10
Quick question.
Can this unit be installed in a Bose Car and still work without changing speakers and adding amps?
I want to change out everything but I would like to do it in two phases.
Thanks,
Nelson
Old Jun 28, 2007 | 05:25 PM
Oli1313's Avatar
Oli1313
St. Jude Donor '09
I have been considering the same unit (Kenwood DNX7100). A local shop quoted $1,300 for the unit and $315.00 for install. Are these fair prices? I know I can get the unit cheaper through some internet electronic shops, but those are usually not manufacturer approved vendors and I'm afraid about warranty issues. Where did you guys purchase yours and was the above an issue?
Old Jun 28, 2007 | 11:10 PM
dynosmith's Avatar
dynosmith
If I add the Kenwood XM receiver -can I use the stock XM antenna? Or if I wanted to change to Sirrus does it use the same type plug?
Old Jun 29, 2007 | 12:23 AM
pentavolvo's Avatar
pentavolvo
you should be able to use stock sat radio antenna
on a C6 you can keep bose and add this unit, its a great piece
Ive always bought from sonicelectronix and never a problem yet
Old Jun 29, 2007 | 12:33 AM
  #33
dynosmith's Avatar
dynosmith
Originally Posted by Nelson10
Quick question.
Thanks,
Nelson
Yes, I just did it in an 07 coupe with Bose / no OnStar (finished it yesterday) - with 7100, bluetooth, camera, video ipod. It all worked really well today...I will keep everyone updated. Also I documented the entire install, alot of good pics if you need any examples.
Old Jun 29, 2007 | 12:35 AM
  #34
dynosmith's Avatar
dynosmith
Thanks for the help - do you know if the Sirrus antenna uses the same style plug?
Old Jun 29, 2007 | 12:43 AM
  #35
dynosmith's Avatar
dynosmith
http://www.abesofmaine.com/item.do?item=KWDNX7100
I know these guys are good to work with and have a great price as well. I personally purchased locally and they matched Crutchfield prices, could have save about $300 over the internet but I installed it myself so...
Old Jun 29, 2007 | 01:50 AM
  #36
jarda's Avatar
jarda
Going to start install of 7100 tomorrow that is the only thing that hasn't changed. Still working on the final amp,speaker setup. Work much better under pressure.....
Jarad
Old Jul 1, 2007 | 02:32 AM
  #37
Reep's Avatar
Reep
How was the sound quality? Good enough to live with until a phase II could be done?
To Kenwood DNX7100
Old Jul 1, 2007 | 03:37 AM
  #38
btrthandan's Avatar
btrthandan
2nd Gear
Started install today on 2005 with bose and Onstar using gmah24b and according to peripheral's website we do not need the chime module(gmahcm). jhowever i have no chimes. does anyone have any input that could help, will be trying to complete install sunday the 1st.
Old Jul 1, 2007 | 08:33 AM
  #39
BuckyThreadkiller's Avatar
BuckyThreadkiller
Successful Plumber
From: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
Do the wheel mounted radio controls still function with the aftermarket unit?
Old Jul 1, 2007 | 09:01 AM
  #40
dynosmith's Avatar
dynosmith
Definitely yes in my opinion!
