Sponsored by: Innova
FS: AUX Input & iPod Interface for C6
Old Jun 24, 2007 | 08:36 PM
ShockwaveGT's Avatar
ShockwaveGT
Default FS: AUX Input & iPod Interface for C6
I just recently traded my Black C6 for a Yellow C6, but the VY one has the NAV in it, so I need a new iPod solution. This means I no longer have a use for my previous iPod solution that was designed to work with the factory BOSE 6-Disc headunit WITHOUT NAV.
The interface is composed of two different pieces of hardware that I purchased in Jan. 2005. The first is the Soundgate AUXGMV3 Auxilary Input Adapter which connects to the 12-pin connector on the back of the BOSE headunit. The second piece is the Blitzsafe UII iPOD® interface which allows you to connect an iPod (except the iPOD Shuffle) to the Auxilary Input Adapter.
The result is a direct signal to your headunit from the iPods line output for a terrific sounding solution for your C6. The iPod will also receive power from this setup so there is no need for external power. You will have to control the iPod from the iPod itself, as this setup does not allow for any control via the headunit.
For more details about this solution, check out my original thread that I posted in Jan. 2005:
http://forums.corvetteforum.com/show....php?t=1251907
Here are the two pieces of hardware connected to each other as they were removed from my black C6:
And here you can see how it looked in my black C6. I just had the wire ran under the center console between the gap so there was no need to drill any holes:
Had these professional installed and removed at a local Tweeter. Works great! I'll take the first $80 for the setup.
Here's the original links to both products:
http://www.logjamelectronics.com/soundauxgm.html
http://www.logjamelectronics.com/blitzuii.html
Please be sure to read the requirements. This works with the BOSE 6-disc system WITHOUT NAV only.
Old Jun 24, 2007 | 08:39 PM
ShockwaveGT
sorry for the double thread post in Audio/Electronics...
My browser hosed up and I didn't think the first took so I refreshed...
