Sponsored by: Innova
power source for RAP w/ window valet
Old Jul 20, 2007 | 10:25 PM
comecorrect's Avatar
comecorrect
Default power source for RAP w/ window valet
Where can I tap into an ACC power source that will allow the HU to play with the window valet. The windows work but the HU doesn't power up. I have an after market HU and connected the ACC wire to the yellow wire in the passenger foot well. Thanks!
MIKE
Old Jul 20, 2007 | 11:38 PM
Vette-kid's Avatar
Vette-kid
I dont think you can just tap into a wire to do this. However, the same Top Down Tech (people that make the window valet) also have a module that will allow you to have that function. Its not cheap, but I think it may be the only way to do it (something about the data bus).
Old Jul 21, 2007 | 10:32 PM
DPG's Avatar
DPG
St. Jude Donor '06
Or you can try to tap into the door switch cause the power windows have that. you can find the harness for that in the kck panel.
Old Jul 21, 2007 | 10:56 PM
comecorrect
Thanks! I will give that a try.
MIKE
Old Jul 22, 2007 | 12:27 AM
Vette-kid's Avatar
Vette-kid
Let me know how that works out. Im interested as well, especially if I can save the $100!
Old Jul 22, 2007 | 01:22 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
I could be totally wrong but I think with the window valet you just use the ignition wire in the stock radio harness
Old Jul 22, 2007 | 02:20 PM
Vette-kid's Avatar
Vette-kid
hmmm...Id love to know for sure on that. Anyone know if the Ignition remains hot? There was a discussion about this a while back, seems the answer was something about the databus. Ill see If I can find the thread, Maybe one of the poster from that will see this and chime in too.
Old Jul 22, 2007 | 02:40 PM
Vette-kid's Avatar
Vette-kid
Found it. From reading over this again it looks like the power window idea would be a no go. Appearantly they are only energized when the window is in transit, so you radio would come on when you move your window, then shut off again . As far as the ignition wire in the stock harness, I believe the function is a bit more complex than that. If you look in this thread below, TheKomoman talks about the RAP in a little detail. The signal is sent from the data bus and then has to be interpreted by whatever accessory is to remain on. So if you taped into stock harness you would indeed have a signal there, but your aftermarket HU wouldnt have a way to interpret that. Thats at least what I got out of it. Maybe Komoman will chime in on this.
http://forums.corvetteforum.com/show....php?t=1731239
Old Jul 22, 2007 | 06:07 PM
comecorrect
Nope didn't work. Thanks!
MIKE
Old Jul 22, 2007 | 06:09 PM
comecorrect
Thanks, I will read the thread.
MIKE
Old Jul 23, 2007 | 01:12 AM
pentavolvo's Avatar
pentavolvo
sorry i couldnt help more
Old Jul 23, 2007 | 08:23 AM
comecorrect
Not a problem, glad you tried to help. Looks like the Accessory valet for me. Thanks everyone!
MIKE
Old Jul 23, 2007 | 10:15 AM
DPG's Avatar
DPG
St. Jude Donor '06
Sorry that didn't work out.
Old Jul 24, 2007 | 09:20 PM
adown's Avatar
adown
It doesn't make sense that the window power wont work. There is an up relay and a down relay. Both would have to have power on one side for the duration of the timer, and only on the other side when the button is depressed.
To power source for RAP w/ window valet
