infinate baffle...
seems like it'd be pretty easy way to get efficient, clean, deep bass.
I haven't given much thought to them in our cars but i was just planning out an IB setup in my house and became curious.
update:
my house project is complete:
http://forums.corvetteforum.com/show...4&postcount=57
i didnt realize there was a low frequency extension drawback. how major are we talking? I've only ever heard on IB setup in a car and i was extremely pleased/suprised, i always thought they would sound like crap (from my limited demos at the tweeter store back east)
Of course, that's unless there's some new configuration I'm not aware of.
A trunk is the ideal configuration for this because you have so much more space to fiddle with the aperiodic membrane. And believe me, the membrane takes a lot of effort and electrical testing to get right. Otherwise it ends up sounding like a vented enclosure where the vent is not correct (flapping, unloading, boomy response...). It's a serious PITA and not for the faint-of-heart or those uninitiated in loudspeaker testing.
http://www.audiogearreviews.com/tech...c_membrane.asp
An infinite baffle is nothing more than a way to mount your sub, or perhaps better said: a type of box for your sub... the 'inside' of the box is 'infinite' in size... a very large trunk for example.
Some home theater guys use their attics as the sub enclosure, and mount the 15" IB subs in a way that isolates the attic from the room.
You don't 'buy' an infinite baffle... you build one.
You can buy an Aperiodic Membrane, however. Aperiodic membranes help provide a better transient response when using a sub in an IB configuration.
Parts Express sells them:
http://www.partsexpress.com/pe/pshow...TOKEN=93986940
Look here for more information:
...or just Google "Aperiodic membrane" for more information.
Hope this helps.
Mark
Two main types of infinite baffle setups:
1 - A board across the seat frame holding one or more drivers facing the interior of the vehicle with no box behind it. The trunk itself acts as the enclosure. This is a traditional "infinite baffle" setup.
2 - A sub in a box where the sub is in the passenger compartment and the back wall of the box is in the trunk and is made of a material that resists air flow. That's called "aperiodic." The membrane causes the driver to behave as if it's in a MUCH larger enclosure than it really is. Sort of like the stuffing inside a sealed box, but the effect is far larger.
In both instances the trunk MUST be reasonably sealed off from the passenger compartment.
not to take this thread totally off topic but could you take a look at this sub:
http://www.soundsolutionsaudio.com/f...howtopic=10024
I stumbled across this and was thinking about using it in an IB setup in my house for ht use. I don't want anything too crazy and this may just be a learning experience for me but It seems like the sub has some potential.
1 - If you heard an IB sub in a store in a box, then you certainly didn't hear it the way it's intended. The idea behind an IB woofer is to use in a trunk without a box because the woofer has such a high Qts to start with. If you put an IB woofer in a box, you just screwed the whole thing up. Than includes anyone who uses an IB sub in a hatchback. I expect nothing less from BB/CC/Tweeter/etc.
2 - Car audio drivers don't tend to work very well in the home, unlike the reverse. Car audio drivers are designed for more of a closed-field listening environment than home drivers. The distortion characteristics of home drivers are one of the reasons they're becoming popular in cars, but not vice-versa.
3 - That particular woofer is not really anything special. Companies like that don't build drivers. They place orders for drivers build to certain parameters and from a menu of parts that result in the characteristics they desire in the final result. I've been seeing clones of that very driver for almost ten years now.
4 - For your home use: find a woofer with very low distortion numbers, high sensitivity, relatively low Vas and a moderate Qts (around 0.3-0.4), and build a box for it. Drivers that qualify are not cheap. Don't expect to get away with spending $100-200 on a quality home driver (only one exception I can think of). If you're set on an IB design in your home, look for a driver with a Qts > 0.6. And don't forget that the back of this woofer has to be in another room.
It's much easier to hear distortion in a home system than in a car system, so don't apply car audio techniques to the home. In the end, the home system can be more rewarding than the car, as long as you make good decisions.
PE does have an IB 'specific' sub with low Qts. when things get a bit less crazy here i'll post a link and specs. It's a low cost driver but i'm not striving for audiophile quality sound in my house (ironic huh?) The other sub i was considering is the fi q18 that gets good reviews, it's ~$300
the back of the woofer will be in the attick.
thanks for your help so far
Oh, yeah back to the topic, I did put 12's in the first two, and a single 18" in the grandam. All three sounded great inside the car when the trunk was closed, but the bass the did not travel much outside the cars.
Tonegan (Foster) 1259 http://www.madisound.com/catalog/pro...oducts_id=1402
Hey, I'm always happy to help anyone who genuinely looks for guidance, as opposed to fanboys who think brand means everything and want to argue without understanding the underlying science.
And I don't care about impressing anyone outside the car. I turned 21 19 years ago.
http://www.partsexpress.com/pe/showd...number=295-455
pe is parts express
the subs at tweeter were mounted in the wall of the listening area (completely closed off room) and the backs of the speakers were open to the loby area
