Sponsored by: Innova
Mp3 compression questions.
Old Aug 4, 2007 | 11:46 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Mp3 compression questions.
This is based on a thead in the C5 forum about the compression of Mp3 files being of horrible quality.
Also this thread:
http://www.caraudio.com/forum/showthread.php?t=114272
Is it possible to:
a) rip files without excessive compression (somthing like 256 kbps or better)
b) convert these files into mp3 or wma files without losing quality
Old Aug 5, 2007 | 12:29 AM
VinceC5's Avatar
VinceC5
Also this thread:
Is it possible to:
depends on what you use to "rip" the music. Windows media gives you options to RIP at different KBPS. I've read many articles on this topic, and it turns out Windows Media Audio Lossless option is one of the better ones.
Old Aug 5, 2007 | 12:41 AM
Kale's Avatar
Kale
256 using LAME will work for 95% of people, I think. 320 is also an option.
I've ripped a lot of stuff at 256.
I'm going to start using Apples encoder... since I play from IPOD.
Anyway, get a program called CDEx, it rips and encodes any quality. Free.
Old Aug 5, 2007 | 01:34 AM
Shangreer's Avatar
Shangreer
I rip all of mine at 320kbps. I find that anything less than that leads to some deficiencies in the high notes. Things like symbol hits tend to warble.
I have used a bunch of programs to do Rips. Most good CD Mastering programs have this ability. Nero, for example.
Good luck.
Old Aug 5, 2007 | 08:38 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Based on my friend Spkrboy's recommendation, I have been using Exact Audio Copy combined with a script called REACT. It rips in lossless, then uses LAME with variable bit rate.
http://wiki.hydrogenaudio.org/index.php?title=REACT
Old Aug 5, 2007 | 10:42 AM
Spkrboy's Avatar
Spkrboy
Hydrogenaudio is the definitive net authority on audio compression. I'm extraordinarily picky about audio, and I despise most forms of mp3. REACT combined with EAC and LAME results in the only tolerable form short of FLAC. It's not perfect but it's far better than Nero, iTunes, and all the other standard rippers.
Old Aug 5, 2007 | 04:37 PM
Black$heep's Avatar
Black$heep
Also this thread:
Is it possible to:
I use windows media player to rip mine at 320 kbps.
You can download several freeware rippers from Afterdawn.
http://www.afterdawn.com/software/audio_software/
You can also finds some at download.com.(Freeware)
http://www.download.com/3120-20_4-0-...49&dlsize=&ca=
To Mp3 compression questions.
