Sponsored by: Innova
Radio Theft Lock
Old Aug 10, 2007 | 09:35 PM
lt4-racer's Avatar
lt4-racer
7th Gear
Default Radio Theft Lock
I bought a used 6-disk OEM radio for my C6 to replace the original single disk unit. The install went well, and the radio worked properly until I switched on the ignition. At that point the theft lock activated, and the party stopped.
The manual says I have to go to the dealer for this issue. Does anybody know if I can override the lock myself?
Chris
Old Aug 11, 2007 | 12:30 AM
Hawk07's Avatar
Hawk07
My understanding is the radio needs your VIN programmed into it as well. Looks like a dealer visit...
Old Aug 11, 2007 | 02:43 PM
EscapePod's Avatar
EscapePod
The procedure for a C5 is at this Tech link, here on the CorvetteForum.
https://www.corvetteforum.com/techti...=164&TopicID=1
It "may" be the same procedure for a C6.
Good luck!
Old Aug 11, 2007 | 10:08 PM
lt4-racer's Avatar
lt4-racer
7th Gear
I tried the C5 trick, and that did not work. I read on another forum that for the C6, an OTC Tech 2 scanner is needed to reprogram the computer to accept this new radio. I don't have access to one; so Hawk07 was right - looks like a dealer visit.
The first dealer I talked to quoted $92 (their hourly rate) and I would have to wait a day. I plan to find a different dealer.
Thanks.
To Radio Theft Lock
